any outstanding problems with snapshot
Till Straumann strauman at SLAC.Stanford.EDU
Wed Feb 5 07:37:50 UTC 2003
Joel Sherrill wrote:
> Hi,
> I want to know what outstanding problems people have with the snapshot.
> I know of a couple:
>   + add-on packages are not building cleanly with latest tools
>   + README.configure is unclear about motorola_powerpc BSP
>   + documentation on cd-working needs to be updated.
>   + want to get Linux tools stable so cygwin and solaris tools
>     can be built
> Anything else?  I have given up on the ada test PRs (274 275)
> for this release.  Fixing that would be enough to make me
> think about another major release though. :)
I spent today playing with the pc386 BSP. Downloaded the cd-working
toolchain (at first, I spent 2 hours in configure-hell because I had
installed the toolchain from the snapshot area - everything got
installed under /opt/gnucross. The wonderful 'configure' "tool" couldn't
handle this [at least not when I followed the instructions in
README.configure] - and I'm not exactly a beginner...). Then, I learned
GRUB, fixed the FXP network chip driver to recognize my card, built
CEXP for i386-rtems etc.
PROBLEMS:
1) Eventually, I got a linkage error: _fcntl_r is missing
    (cpukit/libcsupport/src/fcntl.c should implement it - fix attached
    with PR 340)
It's a good thing that my CEXP/system application tries to pull in
almost the complete libc, librtemscpu, librtemsbsp libraries :-)
2) Another problem was that gcc-target-default.cfg does not
    add the LD_PATHS to the LDFLAGS anymore - is there a good reason
    for this (broke my application)? Hmm - After some research, I found
    that slightly different versions of 'gcc-target-default.cfg'
    are present in make and in c/src/make. Is this correct???
3) There might be some more issues on powerpc - I'll address this
    ASAP.
After supplying a dummy _fcntl_r (calling fcntl) IT WORKED, I'm happy
and ready for a nap...
-- Till
