Automatic Re-Building of BSP
Don donp_news at glasscity.net
Wed Feb 5 21:55:42 UTC 2003
Greg,
Between Joel explaining to me how to find the right samples directory
and your comments, I think I might be able to make some headway.  My
biggest problem, as Joel has probably concluded, is keeping the
directory structure straight!
Speaking of directory structures, you mention " ....... probably time
to start a project in your own tree ......."; would you elaborate on
creating a project tree?  As I mentioned, I seem to be directory
challenged.
Thanks!
Don
> Don writes:
>  > > > Trying to move on to bigger and better things, I found the
bsp.h
>  > needed
>  > > > tailoring.  Some PPC2A registers are not explicitly defined in
the
>  > > > ppcn_60x BSP.  After making the changes and trying to make
my "hello
>  > > > world pluss flash LEDs", I got compile errors indicative of
the
>  > bsp.h
>  > > > changes not being included.
>  > > Are you modifying the hello world in c/src/tests/samples or the
>  > > standalone example application version?
>  > > Either way you can do a make clean in that particular directory.
>  > > I know this is what I do so unless Ralf enlightens us both, that
>  > > is all I know to offer.
>  > Tried 'make clean', 'make all', and 'make' in the stand-alone
directory
>  > with no luck.
> When modifying a bsp, the dependencies sometimes don't make it all the
> way up to a top-level make.  One thing I do in this case is a 'make
> clean' at a conveniently low level in the bsp,
> (perhaps c/src/lib/libbsp/<whatever processor>/<whatever bsp>)
> so a minimal set of files is deleted, then a top-level make is run.
> The now-larger set of deleted files will trip dependencies and cause
> the bsp to be rebuilt, but not rebuild all of rtems.  Its a little
> clumsy because of the make in 2 different locations, but you can
> always be clever and do things like;
> make clean; pushd /opt/rtems/build/my-bsp; make install; popd
> from the <whatever bsp> directory above.  That will delete the
> compiled bsp, jump to the top level and make install which will
> rebuild the bsp, relink whatever is necessary and install the
> libraries.  You'll still go thru the library assembly phase, but it
> avoids building the score/posix/networking trees.
> note the use of ; instead of &&, this causes the command series to be
> completed regardless of errors so you will be in the right place to
> make clean for the next pass.
> I am assuming you're using a build directory different from the
> install directory; a temp directory in which configure generates a
> tree that make uses to compile, the results of which are installed
> into a different tree that is intended for use by appliation software.
> The make steps above want to be done in the temp tree; you edit in the
> source tree and the install tree gets the final result.
>  > > > The way I understood things, enabling maintainer mode (--
enable-
>  > > > maintainer-mode) caused any required files to be updated when
>  > make of
>  > > > the user code is performed.  Obviously, I am off base on this
>  > notion!
>  > > > In tweaking the BSP, do I need to rebuild it using
the "verbose"
>  > > > approach shown above?  Did I miss something with --enable-
>  > maintainer-
>  > > > mode?  Is there a better way?
>  > > Ralf can probably explain it for sure.  But I am only positive
that
>  > > --enable-maintainer-mode verifies configure* and Makefile*
>  > dependencies
>  > > (those based upon auto* tools).
>  > So, for the time being a 'full' BSP build is probably the best
>  > approach?  I guess my concern is that there might be a problem re-
>  > building the BSP on top of an existing version of the same BSP.
(Maybe
>  > I am too conditioned to the Windows app approach that 'highly
>  > recommends' previous versions be un-installed before installing
new
>  > versions.  ;)  )
> Mod the dependency stuff above, bsp tweaks should compile just fine-
> no special configure parameters should be required unless you're
> creating a new bsp or adding files.  I'm not sure what you mean about
> existing vs older versions of the bsp in the same directory.
> If you're modifying the test programs, its probably time to start a
> project in your own tree- you'll find it much easier to work with.
> Gregm
