Help With coldfire needed
    Fabrizio Pirovano
    rtems.thysys at tiscalinet.it
    Fri Feb  7 14:04:35 UTC 2003
Hi all,
from my application on coldfire targets I have evidence that  gcc3.2.1 is
affected  by a bug similar to PR8309 (if  I compile my code with optimization level> 0).
I obtain correct code (and all work fine)  if  I use the option  -O4 -fno-force-mem. (O4 or O1, O2 O3)
I am trying to investigate the problem:
from a C code as
short I
for(I=0; I<xx ;I++)
but located inside a function that use many dinamic variables,
I obtain from gcc an assembler code as:
move. w d0, 0x10(a6)                     (I=0 ;  I   is declared as  short
and 0x10(a6)  is his place)
moveq.l   #1,d5                              (I++)
add.l     d5,0x10(a6)        (!!!!! : correct code is add.w d5,0x10(a6)  )
Best regards
Fabrizio Pirovano
URL: <http://lists.rtems.org/pipermail/users/attachments/20030207/435bf6db/attachment.html>
