Why _ThreadProcessSignalsFromIrq() in new exception processing?
Valette Eric eric.valette at free.fr
Fri Feb 7 14:23:46 UTC 2003
Sergei Organov wrote:
> Could somebody please explain what is the purpose of call to
> _ThreadProcessSignalsFromIrq() in the new-exception-processing from the
> shared_raw_irq_code_entry? Should it be implemented in the old exception
> processing for proper RTEMS behavior?
I guess, you will not get fully working posix signaling without doing
this (look at pthreadkill or signalsend). This block of code is used to
trigger a processing on the newly switched thread that end up calling
_API_extensions_Run_postswitch.
NB : The code was already there on ix86 when I implemented the new
exception model I just keeped it. When going to PPC, the call was
missing so I added it.
In most advanced RTOS, there are things that should be done on the
current thread that have been trigerred as the result of a system call
from isr and that must be deffered until the thread runs again... In
that case having a context is very usefull. I wanted to use it to
implement a call to debugger from keyboard in particular....
> BTW, is the new exception processing model documented somewhere as this call
> is not the only violation of the old documentation describing how
> exceptions/interrupts should be handled by BSPs?
If documentation is not accurate, trust the code. If old code is broken,
do not stick to it :-)
    __
   /  `                   	Eric Valette
  /--   __  o _.          	6 rue Paul Le Flem
(___, / (_(_(__         	35740 Pace
Tel: +33 (0)2 99 85 26 76	Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
