Re-Building RTEMS Fails
Don
donp_news at glasscity.net
Fri Feb 7 18:29:19 UTC 2003
In trying to rebuild my BSP for the PPC2A, I have run into a problem
rebuilding RTMES. It gets about halfway through the build and dies:
configure: creating ./config.status
config.status: creating Makefile
config.status: creating size_rtems
configure: configuring in powerpc-rtems/c/make
configure: running /bin/sh '../../../../rtems-ss-
20021118/c/make/configure' '--prefix=/opt/rtems' '--host=powerpc-
rtems' '--build=i686-pc-linux-gnu' '--target=powerpc-rtems' '--disable-
posix' '--disable-cxx' '--enable-maintainer-mode' '--enable-
rtemsbsp=ppcn_60x' '--with-target-subdir=powerpc-rtems' '--exec-
prefix=/opt/rtems/powerpc-rtems' '--cache-file=/dev/null' '--
srcdir=../../../../rtems-ss-20021118/c/make'
checking for gmake... gmake
checking for RTEMS Version... ss-20021118
checking build system type... i686-pc-linux-gnu
checking host system type... powerpc-unknown-rtems
checking target system type... powerpc-unknown-rtems
checking rtems target cpu... powerpc
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for mawk... no
checking for gawk... gawk
checking whether gmake sets ${MAKE}... yes
checking for powerpc-rtems-strip... no
checking for strip... strip
checking whether to enable maintainer-specific portions of Makefiles...
yes
checking if cpu powerpc is supported... yes
checking for style of include used by gmake... GNU
checking for powerpc-rtems-gcc... no
configure: error: no acceptable cc found in $PATH
configure: error: /bin/sh '../../../../rtems-ss-
20021118/c/make/configure' failed for c/make
sed: can't read confdefs.h: No such file or directory
[root at acuserver build-rtems]#
The command line is:
[root at acuserver build-rtems]# ../rtems-ss-20021118/configure --
target=powerpc-rtems \
> --disable-posix --disable-cxx --enable-maintainer-mode \
> --enable-rtemsbsp="ppcn_60x" --prefix=/opt/rtems
I have gone as far as trying to unistall and reinstall the 6 RTEMS
tools RPMs. However, when I go to unistall them, it tells me they are
not installed, but when I go to install them, it says they are already
installed.
I'm lost! Help?!
Thanks!
Don
www.dynamic-controls-inc.com
