Re-Building RTEMS Fails
Don donp_news at glasscity.net
Fri Feb 7 19:08:08 UTC 2003
> Don wrote:
> > In trying to rebuild my BSP for the PPC2A, I have run into a problem
> > rebuilding RTMES.  It gets about halfway through the build and dies:
> > checking for powerpc-rtems-gcc... no
> > configure: error: no acceptable cc found in $PATH
> > configure: error: /bin/sh '../../../../rtems-ss-
> > 20021118/c/make/configure' failed for c/make
> > sed: can't read confdefs.h: No such file or directory
> > [root at acuserver build-rtems]#
> The problem is pretty specifically pointed out.  You do not
> have powerpc-rtems-gcc in your PATH.  Do an echo $PATH
> and see if /opt/rtems/bin is in it.
Well, it was actually in the PATH twice!  Deleted one instance and ran
it again with no luck.  However, being in the PATH assumes
that /opt/rtems/bin exists.  Turns out that /opt is empty!  I may have
inadvertantly deleted it in my rompings through the system :o
This probably explains my RPM problem too, huh?  Arrrrgh! :(
Suggestions?
Thanks!
Don
> > The command line is:
> > [root at acuserver build-rtems]# ../rtems-ss-20021118/configure --
> > target=powerpc-rtems \
> > > --disable-posix --disable-cxx --enable-maintainer-mode \
> > > --enable-rtemsbsp="ppcn_60x" --prefix=/opt/rtems
> > I have gone as far as trying to unistall and reinstall the 6 RTEMS
> > tools RPMs.  However, when I go to unistall them, it tells me they
are
> > not installed, but when I go to install them, it says they are
already
> > installed.
> > I'm lost!  Help?!
> > Thanks!
> > Don
> > www.dynamic-controls-inc.com
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
