Why _ThreadProcessSignalsFromIrq() in new exception processing?
Mon Feb 10 13:50:26 UTC 2003
Sergei Organov wrote:
> Eric Valette <eric.valette at free.fr> writes:
> > > Most of BSPs do basically the same thing. If
> > > _ISR_Signals_to_thread_executing is non-zero, they set it to zero and
> > > either call _Thread_Dispatch or return to _ISR_Thread_dispatch that in
> > > turn calls _Thread_Dispatch. This is the documented way to do things. Fine
> > > so far. However, there are 3 BSPs that do this differently in an
> > > undocumented way. Instead of calling _Thread_Dispatch directly or
> > > indirectly, they call their own _ThreadProcessSignalsFromIrq. Maybe it's
> > > OK to do it this way, but the question is: why? I guess there should be
> > > some reason for that. What is the reason?
> > The reason is that having a context to implement software exception (which
> > is what this code does even if not said that way and used in a particular
> > way for posix signal) is almost mandatory (e.g to correctly implement
> > signals on alternate stack, kernel debuggers, ...). So, when implementing
> > exception on those three BSP, I added the push of a context similar to the
> > one pushed on real hardware exceptions as this path is very unfrequent and
> > anyway performs heavy operation like functions calls. The normal path is
> > optimized as usual (or maybe a little bit more even).
> This is what I've asked about. Your words "almost mandatory" imply that the
> BSPs that don't do that are "almost broken", isn't it? And Joel says they are
> fine.
I was only referring to the processing of signals by ISR disptaching
code NOT to ANY exception handling processing.  The only requirement I
stated was that the exit patch of the ISR processing code MUST honor
that if an ISR sent a Classic API or POSIX API signal to the currently
executing thread, then that signal must be processed befure the thread
returns to its normal execution if that signal is enabled.
The comment about exceptions which might have confused you is that
some software assumes that it will get a SIGFPU for a floating point
exception.  Thus some exception handlers will generate POSIX signals
to provide a more UNIX-like environment.  The GNU Ada run-time library
actually uses POSIX signals as the underlying mechanism for Ada
language level interrupt processing.
> > > If there is one, then why the _ThreadProcessSignalsFromIrq is not in the
> > > RTEMS core (like _Thread_Dispatch) and why not all the BSPs call it?
> > Because the CTX argument is processor dependent and that the actual handling
> > of the software exception may also well contain system/board specific code.
> Current code doesn't use CTX argument and I mean that part of code. It is
> processor/bsp independent (in fact it is a copy of a few last lines of
> _Thread_Dispatch) and so should better reside in the kernel, isn't it? It
> could be then called both from _Thread_Dispatch and from
> > > Is there an intention to eventually turn all the BSPs to this new calling
> > > sequence?
> > I do not care about that but would like to understand your resistance to
> > adopt the new exception handling code
> Resistance is just helpful. There should be a reason to switch to something
> new when old works, not a reason to don't switch, and still I didn't see
> anything in the new code that is significant enough *for me* to justify the
> switch. Also I prefer to stay with the majority whenever possible, and the new
> exception processing is not yet the majority, I think.
> > (the EABI broken argument can be fixed by adding a single ASM instruction to
> > restore R2 before actually calling the irq handler).
> As soon as I've noticed it, that's not a problem anymore. It would be a real
> problem if I've started to use the code without noticing that. I know enough
> to fix it myself or even to re-implement it entirely if required. I just
> wanted to let you (and others) know there possibly is a problem. An
> interesting thing though is that there are currently 4(!) almost identical
> copies of the 'irq_asm.S' in the PPC BSPs that looks to me as rather bad
> style.
> > So far you seems to critize something that anyway
> >       1) you do not use
> >       2) have not proposed to enhance/fix yet
> Please don't get me wrong. Criticism is not my goal. I just try to understand
> particular differences between two implementations, reasons behind them, and
> consequences of switching from old to new exception processing.
> > I think recent discussion on the mailling list made it clear that :
> >       1) IRQ API should be enhanced
> Agreed.
> >          and the API proposed on the three BSP you mention is already a big
> >          step forward,
> Maybe. You insist it is, somebody else posted different feeling. Anyway, API
> has nothing to do with the implementation details I was asking about in this
> thread, or my understanding of the term "API" is different than yours.
> >       2) Exception handling API is also required on many CPU to handle
> >          recoverable exception, implement debuggers (e.g remote debugging)
> >          and was indeed missing in PPC, Ix86.
> Yet I didn't say even single word about exception handling. If you are
> interested in my opinion though, I agree with you that it's a good idea to
> keep exceptions API separate from ISRs API (they can share [parts of]
> implementation though).
> Sergei.
