"New" vs. "Old" Style Interrupts
Mon Feb 10 23:23:29 UTC 2003
Till Straumann wrote:
> Don:
>   - the 'old' style interface (rtems_interrupt_catch()) is described in
>     chapter 6 of the RTEMS C User's Guide.
>   - I don't know of any docs (besides the source code
>     [libbsp/powerpc/shared/irq/irq.c]) for the 'new' style API.
The biggest difference is in the way the BSP space owns the
ISR dispatching code.  In the "old old" API, it was generally
in the score/cpu/XXX directory.  So this BSP will have to
build the shared/irq code.  I think the motorola_powerpc BSP
does this already.
> I looked through the ppcn_60x BSP. Here's what I found:
>   - this BSP does NOT adhere to neither the 'old' nor the 'new' API
>     but provides its own (startup/setvec.c: set_vector()).
This is how the "old old" API BSPs did it if they had a PIC that had
to be touched as part of installing the ISR handler.  So it really isn't
unique.
But regardless, the installation of every ISR handler (not that many)
will have to change.
>   - the BSP has a 'driver' for vmeUniverse although mine is far more
>     complete (including support for VME interrupts, DMA etc.).
>   - Porting my driver to your BSP should not be too hard:
>     1) vmeUniverse needs PCI configuration space support from the
>        BSP:
>          a) a routine 'pciFindDevice' (need to be macro-aliased
>             to the proper routine/wrapper of your BSP) who scans
>             PCI config space for the universe bridge.
>             You could add 'libbsp/powerpc/shared/pci/pcifinddevice.c'
>             to your BSP substituting the pci_read_config_xxx calls
>             by the ones present on your BSP (see step 2))
>          b) routines to read PCI config registers (byte and longword)
>             [on your BSP these are PCIConfigRead32/PCIConfigRead8;
>             hence you could replace the macros on top with
>              #define pciConfigInLong PCIConfigRead32
>     2) vmeUniverse needs to know how to acknowledge a PCI interrupt
>        In your case, nothing needs to be done
>              #define BSP_PIC_DO_EOI do {} while (0)
>     3) Install the VME ISR dispatcher: replace the 'new' style
>        interrupt installer (BSP_install_rtems_irq_handler()) by
>        a proper call to 'set_vector()'
>     4) I might have missed something...
> I attach the latest version of the vmeUniverse driver in case you want
> to try to do the port (should be easy).
> For the sake of ease of maintenance, I just added a few hooks making it
> possible to override some things without having to modify the driver code.
>   1,2) PCI config space access macros may be overriden via CFLAGS
>        when compiling vmeUniverse.c, hence:
>        CFLAGS += -DBSP_PIC_DO_EOI=do{}while(0)
>        CFLAGS += -DBSP_PCI_CONFIG_IN_LONG=PCIConfigRead32
>        CFLAGS += -DBSP_PCI_CONFIG_IN_BYTE=PCIConfigRead8
>        (you still need to supply BSP_pciFindDevice)
>   3)   create your own version of vmeUniverseInstallIrqMgr():
>        copy to a separate file and replace
>        BSP_rtems_install_irq_handler() by a proper call to set_vector.
>   4)   Send me email :-)
> USAGE NOTE: To fully initialize the driver, the following steps can/must
> be performed:
>   vmeUniverseInit();  /* MANDATORY: Driver Initialization */
>   vmeUniverseReset(); /* OPTIONAL: Reset most registers to a known state;
>                        * if this step is omitted, firmware setup is
>                        * preserved
>   vmeUniverseMasterPortCfg(...); /* OPTIONAL: setup the master windows
>                                   * (current setup preserved if omitted)
>   vmeUniverseSlavePortCfg(...);  /* OPTIONAL: setup the slave windows
>   vmeUniverseInstallIrqMgr();    /* NEEDED FOR VME INTERRUPT SUPPRORT
>                                   * initialize the interrupt manager.
>                                   * NOTE: you need to call your own
>                                   * version of this routine here
> For an example of init/setup, consult
> libbsp/powerpc/shared/vme/vmeconfig.c (not yet submitted to OAR;
> attached to personal email).
> Don wrote:
> > Is there a document or references which describe the differences
> > between "old style" RTEMS interrupts and "new style" ones?  My
> > understanding is that the ppcn_60x BSP uses the old style.  I am
> > looking at potentially using the Tundra Universe functions (in
> > libbsp\shared\vmeUniverse; by Till Straumann), and a note in the code
> > says that the vmeUniverse requires new style interrupts.
> > Thanks!
> > Don
> > www.dynamic-controls-inc.com
