RTEMS Event Receive Issue
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Feb 11 22:58:50 UTC 2003
Thanks for the optimization and to those who reviewed
it and said "yeah verily it is good." :)
It is merged.
Mike Siers wrote:
> Hi All,
> Attached is a small patch to the network daemon task
> code.  I just added code to check the return value of
> the rtems_bsdnet_event_receive function.  Only when
> this function returns a SUCCESSFUL status, will the
> event flags be checked.
> This is more of a code cleanup issue than a bug.  The
> patch will just ensure the ipintr() and arpintr()
> functions are only called when a event is signaled.
> Please review and let me know if you think this is
> the correct fix.  The rtems_glue.c file is in the
> cpukit/libnetworking/rtems directory.
> Thanks
> Mike Siers
> --- rtems_glue.c        Fri Nov  1 12:43:57 2002
> +++ rtems_glue.new      Mon Feb 10 10:09:51 2003
> @@ -493,6 +493,7 @@
>  static void
>  networkDaemon (void *task_argument)
> +       rtems_status_code sc;
>         rtems_event_set events;
>         rtems_interval now;
>         int ticksPassed;
> @@ -505,14 +506,18 @@
>                         timeout = c->c_time;
>                 else
>                         timeout = RTEMS_NO_TIMEOUT;
> -               rtems_bsdnet_event_receive (NETISR_EVENTS,
> +               sc = rtems_bsdnet_event_receive (NETISR_EVENTS,
>                                                 RTEMS_EVENT_ANY | RTEMS_WAIT,
>                                                 timeout,
>                                                 &events);
> -               if (events & NETISR_IP_EVENT)
> -                       ipintr ();
> -               if (events & NETISR_ARP_EVENT)
> -                       arpintr ();
> +               if ( sc == RTEMS_SUCCESSFUL ) {
> +                       if (events & NETISR_IP_EVENT)
> +                               ipintr ();
> +                       if (events & NETISR_ARP_EVENT)
> +                               arpintr ();
>                 rtems_clock_get (RTEMS_CLOCK_GET_TICKS_SINCE_BOOT, &now);
>                 ticksPassed = now - ticksWhenCalloutsLastChecked;
>                 if (ticksPassed != 0) {
