A few BSPs have buggy ISR processing.
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Feb 11 23:39:16 UTC 2003
Sergei Organov wrote:
> While looking at ISR processing code in different BSPs I've noticed that a few
> BSPs have bugs in the code. All the observations are made in the latest
> 20030128 snapshot. The BSPs affected are:
> sh/sh7032
> sh/sh7045
> sh/sh7750
> c4x
> a29k
I think you are correct and am fixing the code to be even more
correct.
> The first 4 have the same bug:
> - if(( _Context_Switch_necessary) || (! _ISR_Signals_to_thread_executing))
> + if(( _Context_Switch_necessary) || (_ISR_Signals_to_thread_executing))
And this bug propagation is because the sh2, sh4, and c4x versions were
all based upon the original sh1 implementation.  The a29k is a special
case.
I have rewritten the logic to be as follows:
  /* nested interrupt */
  if ( _ISR_Nest_level )
    return;
  /* outermost ISR but inside RTEMS dispatching critical section */
  /* things will be evaluated at the end of the critical section */
  if ( _Thread_Dispatch_disable_level ) {
    _ISR_Signals_to_thread_executing = FALSE;
    return;
  /* outermost interrupt and evaluation could be necessary */
  /* if either condition is true, clear the flag and dispatch */
  if ( _Context_Switch_necessary || _ISR_Signals_to_thread_executing ) {
    _Thread_Dispatch();
I am nearly 100% certain that the above logic ensures that the
outermost interrupt will always clear the
boolean.
> Here are the relevant lines:
> rtems-ss-20030128/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c:305:      if(( _Context_Switch_necessary) || (! _ISR_Signals_to_thread_executing))
> rtems-ss-20030128/c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c:308:      if(( _Context_Switch_necessary) || (! _ISR_Signals_to_thread_executing))
> rtems-ss-20030128/c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c:305:      if(( _Context_Switch_necessary) || (! _ISR_Signals_to_thread_executing))
> rtems-ss-20030128/cpukit/score/cpu/c4x/irq.c:77:    if (_Context_Switch_necessary || !_ISR_Signals_to_thread_executing ) {
> The a29k fails to reset _ISR_Signals_to_thread_executing to FALSE here:
> rtems-ss-20030128/cpukit/score/cpu/a29k/cpu.c:274:    (_Context_Switch_necessary || _ISR_Signals_to_thread_executing ))
> Sergei.
