__getpid.c & pid_t
Salman unix at gofree.indigo.ie
Thu Feb 13 21:34:23 UTC 2003
On Wed, 2003-02-12 at 23:06, Salman wrote:
> On Wed, 2003-02-12 at 14:46, Ralf Corsepius wrote:
> > Am Mit, 2003-02-12 um 15.26 schrieb Salman:
> > > I'm stuck at this error message here, no matter what I do :(
> > > gcc --pipe -isystem ../../../.././pc386/lib/include -DHAVE_CONFIG_H
> > Wrong gcc. This should be the target gcc, in your case i386-rtems-gcc.
> Ralf, could you confirm which patch is to be used for newlib.
> /ftp/pub/rtems/snapshots/c_tools/gcc3.2.1newlib1.11.0-1/source
> outlines
> newlib-1.11.0-rtems-20030120.diff 24-Jan-2003 10:11   138k
> as the only patch for newlib.
> /ftp/pub/rtems/snapshots/c_tools/source
> outlines a newer patch
> newlib-1.11.0-rtems-20030203.diff  04-Feb-2003 12:59    25k
> but this latter one has significantly less contents in comparison to
> first one.
> would newlib-1.11.0-rtems-20030203.diff *alone* suffice?
sorted :-)
something in my system is too new, and is causing these problems.
rtems compiles and builds easily (without any sweat) on any other linux
distro which i tried.
Salman
