multiprocessor booting
Francesco Poletti fpoletti at libero.it
Fri Feb 14 20:01:22 UTC 2003
Hy, only one simple questions. I have seen that when I'm in multiprocessor booting  before the application tasks start every node send a packet in broadcast at all the other node. If the Init task is defined as local is things right? If yes why? Which kind of communications may happen?
Thanks to all Francesco.
