SYSV / EABI compliance
Till Straumann
strauman at SLAC.Stanford.EDU
Tue Feb 18 01:49:33 UTC 2003
Hi.
Today, I worked on getting the powerpc/shared BSP
compliant with SYSV / EABI regarding the use of the
small data area(s).
Looks pretty good. I was able to build and run a
major application (RTEMS + networking + CEXP) using
the '-meabi, -msdata=eabi' flags without problems
(yep, I rebuilt RTEMS -msdata=eabi).
I encountered one problem, however: Certain parts of
the system (mostly BSP specific stuff, but also
cpukit/libnetworking/kern/kern_sysctl.o) access
linker defined symbols in the following way:
/* with -msdata=eabi, the compiler assumes
* this variable's address will be linked
* in the short data area.
extern int some_linker_defined_address;
/* use the address here */
yyy( (unsigned) & some_linker_defined_address )
When compiling with -msdata=eabi, a linker error results
because the compiler generates code who tries to locate
the address in a short data area while it is actually
an absolute address.
I solved this by declaring the bogus variable
(only the address has a meaning) as an array of unknown
size:
/* compiler doesn't know the size, hence access is
* through an absolute address
extern int some_linker_defined_address[];
yyy( (unsigned)some_linker_defined_address )
Does anyone have a better solution / suggestion?
-- Till
