RTEMS web server
Charles Steaderman
charlies at poliac.com
Wed Feb 19 23:32:55 UTC 2003
Valette Eric wrote:
> Wendell Thompson wrote:
>> Does the webserver support either client-side Java scripts or
>> server-side PHP scripts?
As far as I know, the web server has little to do with /client-side/Java
scripts. Simply include the JavaScript in your HTML and the client
should process it. According to GoAhead's documentation, they support
server-side ASP although I cannot tell you how complete the
implementation is or how much resources it uses.
>> Is there documentation I've overlooked?
>> Thanks in advance...
> The RTEMS web server is just an *very outdated* port of the goahead
> web server. So you can find docs on the goahead web site...
Actually, I believe that the latest snapshots include Version 2.01 of
the GoAhead web server and the latest version is 2.04.
> BTW : could someone pick up a recent version make a patch and apply it
> to rtems...
Charlie Steaderman
VP Engineering
Poliac Research Corporation
Phone: 952.707.6245
Cel: 612.242.6364
URL: <http://lists.rtems.org/pipermail/users/attachments/20030219/922085c7/attachment.html>
