Relating rtems_symbolic_irq_name to vector number
till strauman at slac.stanford.edu
Thu Feb 20 16:50:21 UTC 2003
Yeah, it's confusing. Look in "c/src/lib/libbsp/powerpc/shared/irq/irq.h"
If I remember right (am currently at home), The 16 ISA interrupts are first,
then come the OpenPIC interrupts.
You'd have to know which PCI interrupt the chip is using and how your
board routs that IRQ to the OpenPIC. Let's say it uses IRQA and that's
hooked to IRQ8 at the OpenPIC. The correct name would then be
8 + BSP_PCI_IRQ_LOWEST_OFFSET
OTOH, if the PCI configuration registers are set up correctly by the
firmware, you should be able to just read the INTERRUPT_LINE
register from PCI configuration space.
The RTEMS/ppc/shared BSP uses a 1:1 mapping between interrupt
line and 'name'.
HTH
-- Till
wrote:
>I'm working on getting multiple DEC21140 units to work, so far I'm
>making progress- a single board arrangement still works... ;) But I'm
>not quite sure how to relate an irqname to the vector that comes in on
>the interrupt.  From looking at the bsp's irq management defines it
>seems like theres probably a way to work from one to the other, but
>due to me not having lots of experience with the ppc, I'm not sure
>where to look.  Any hints are appreciated.
>Thanks,
>Gregm
