PPC IRQ routing tutorial (was Re: Bugs in the PPC/shared interrupt code + dec21140)
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Sun Feb 23 20:31:59 UTC 2003
till writes:
 > gregory.menke at gsfc.nasa.gov wrote:
 > -- snip --
 > >It seems that RTEMS simply uses the default content of the
 > >PCI_INTERRUPT_LINE register, blindly using it as the vector.  It would
 > >be useful to include something in the revised irq api to provide some
 > >means of allocating vectors rather than simply picking arbitrary ones.
 > >Would traversing the vector list to find unused entries be enough?
 > > > >  --> fix to this would require the dec21140 driver to
 > > > >      a) add the correct PIC_IRQ_LOWEST_OFFSET to the
 > > > >         PCI_INTERRUPT_LINE
 > > > >      b) bootloader would have to do some fixup on the
 > > > >         PCI_INTERRUPT_LINE register to replace the
 > > > >         ISA interrupt lines with the OpenPIC ones.
 > > > > --> submitted as PR#361
 > > > > Interesting
 > >I'm completely overhauling the dec21140 driver right now to put it
 > >into line with the existing vectoring api
 > What do you mean by 'the existing vectoring api'?
Properly honoring the "ison" function in conjunction with hardware
initialization as suggested by the comments and the irq management
functions- so no new functions as such, instead I'm changing the
existing code around to fit how the bsp wants to work with the irqs.
 > Before you completely overhaul the dec21140 driver, _please_ make sure you
 > understand what's going on.  Note the difference between an interrupt LINE
 > and an interrupt VECTOR: (the explanation is slightly geared towards the
 > PowerPC architecture example)
I'm developing an understanding of the issue.  The significant issue
in changing around the driver is getting the vectoring straight- and
thats what I'm working on now.  I've been suspecting a mismatch betwen
the INTERRUPT_LINE and vector and have been reading thru the code to
work things out- your comments below are a big help.
Thanks for the long explaination below, I'm archiving it.  I'm aware
of several of the issues you raise, but I appreciate the clarification
on the others.  I am somewhat confused about the distinction between
the PCI_INTERRUPT_LINE and PCI_INTERRUPT_PIN.  From your text below,
it sounds like the INTERRUPT_LINE is acting more like something
hardware related than a vector- whereas from reading the PCI spec, I
interpreted the INTERRUPT_PIN in be that role.  Could you comment on
how they're different?
Thanks,
Gregm
 > - an interrupt LINE is a a hardware resource used by the interrupter
 > ("device")
 >    to signal an event (IRQ) to the CPU. You can think of the interrupt
 > line as of
 >    a 'wire', usually it is one wire amongst others on a bus.
 >    Many computers provide  more interupt lines than the CPU itself has. They
 >    usually incorporate PICs (interrupt controllers) to manage and multiplex
 >    multiple interrupt lines into a single output who is connected to the CPU
 >    (or even a cascaded PIC).
 >    E.g. the PowerPC has one 'external exception (EE)' input pin which is
 > used to
 >    interrupt the CPU. An 'OpenPIC' interrupt controller is connected to
 > EE. The
 >    OpenPIC has sixteen 'external interrupt' inputs. On some platforms,
 > one of
 >    these inputs is used to cascade a second, legacy ISA PIC (which usually
 >    itself is a cascade of two PICs)
 > -  An interrupt VECTOR is a software resource, a mere 'number'  generated
 >    by the interrupter and read by the CPU during an interrupt
 > acknowledge cycle.
 >    (Originally, the term 'vector' was introduced on hardware which supports
 >    reading the vector during an interrupt acknowledge cycle and directly
 > branch to
 >    a vector-specific ISR)
 >    This is useful to distinguish amongst different interrupters. Here
 > are two
 >    examples:
 >      a) VME: The VME bus supports 7 interrupt lines (AKA 'levels') AND
 > reading
 >           a vector from the bus as part of the IACK (interrupt
 > acknowledge) cycle.
 >           A VME device 'knows' its vector number (hardcoded or
 > programmed into
 >          a device register during setup by the driver) and puts it on
 > the bus during
 >          IACK. --> The CPU, upon reception of an interrupt on one of the
 > 7 levels
 >          does IACK and identifies the interrupter based on the vector.
 >      b) PowerPC/PCI/OpenPIC. The PCI bus has 4 interrupt lines (INTA..INTD)
 >          and NO concept of an interrupt vector. If several devices share
 > a PCI
 >          interrupt line, software has to query all devices to identify
 > the interrupter.
 >          The OpenPIC, as already mentioned, has 16 interrupt input pins.
 > It also
 >          supports 'vectors' in hardware. This means that each of the 16
 > inputs
 >          can be associated with a number (vector) which is produced by the
 >          OpenPIC as a result of an interupt acknowledge command. It's simply
 >          a fast way of identifying the currently active input pin (with
 > the highest priority).
 >          Hence, in this case, the vector is not generated by the
 > interrupting device
 >          but by the OpenPIC itself.
 > After this lengthy introduction, I hope it becomes clear that
 > 1) OpenPIC 'vectors' are (transparently) handled by the BSP. They are used
 >      internally to identify the interrupting pin on the OpenPIC (the
 > vectors happen
 >      to be identical to the OpenPIC interrupt line number + 16, i.e. the
 > interrupt
 >      "NAME").
 > 2) The motorola Powerpc boards have ~32 interrupt lines. 15 ISA interrupts
 >      and 15 OpenPIC interrupts. (the ~ is due to the fact that some
 > lines are
 >      used for cascading the PICs and are not usable by devices). The
 > interrupt
 >      'NAME' is a number defined by the BSP's IRQ API. Names are an alias
 >      for interrupt lines starting with the ISA interrupts. E.g. the 2nd
 > input of the
 >      OpenPIC has 'name' 17, the 5th ISA interrupt has the 'name' 4
 >      (I start numbering pins with 1, names start with 0 - unusable lines
 >       [cascade] still happen to have a 'name').
 > 3) RTEMS has NO WAY of knowing how interrupt wires/lines are routed.
 >      The board designer decided to which OpenPIC input he/her wanted to
 >      connect the DEC21140 device. Likewise for PMC/PCI interrupts
 > INTA..INTD.
 >      These four are connected to four different OpenPIC interrupt lines only
 >      known to the board designer (and the BSP developer).
 > 4) Usually, the OpenPIC is used for PCI interrupts. Firmware should set
 >      the PCI INTERRUPT_LINE config register to the correct line used by
 >      the respective device on the particular board. Hence, it makes sense
 >      for a driver to use that information. When using the
 >      BSP_install_rtems_irq_handler() API, it needs to be translated into
 >      an irq NAME, however (by adding BSP_PCI_INTERRUPT_LOWEST_OFFSET).
 >      Makes sense, doesn't it? Read a PCI_INTERRUPT_LINE, but the
 >      API requires a 'name' --> conversion necessary.
 > 5) Unfortunately: motorola/ppc boards connect a couple of devices to
 > _multiple_
 >      interrupt lines (i.e. ISA _and_ OpenPIC inputs) and for legacy
 >      reasons set the PCI_INTERRUPT_LINE register to the ISA line.
 >      Since the RTEMS driver (if it wasn't buggy) assumes the DEC21140
 >      to be a PCI device and hence hooked to the OpenPIC, it uses the
 >      wrong name. Note that if the PCI API was unified across x86/ppc,
 >      ISR installation could well be identical (since the BSPs share the
 >      IRQ API).
 > It has been suggested that the BSP simply define 'symbolic names' for
 > interrupts which should then be used by the driver. The driver would then
 > not use PCI_INTERRUPT_LINE but a symbolic constant such as
 > BSP_IRQ_NAME_DEC21140. Since the BSP developer knows the physical
 > interrupt routing, this sounds like a good solution, doesn't it?
 > NO, IT DOESN'T. It's OK for non-PCI on-board devices, but for PCI it is BAD.
 > (It is one of the reasons why PCI was invented).
 > Imagine, you want to support multiple instances or PMC cards. How are you
 > going to know what slot it will be plugged into? You will have to pass
 > something like BSP_IRQ_PCIINTA to driver initialization. And recompile.
 > What if the PMC module is swapped into another slot after a couple of
 > months? Oh  - forgot to modify the application (now using BSP_IRQ_PCIINTB)
 > and recompile.
 > IMO, the only solution to this is having fixup code in the BSP startup on
 > boards with buggy/incomplete PCI initialization firmware.
 > Sorry for the long message
 > -- Till
 > > and to support multipleu
 > >units.  Right now the built-in dec21140 still works (whew...), and the
 > >2nd unit is addressing OK but having interrupt problems.  I'll give
 > >the above a try.
 > >I REALLY wish somebody would tell me where to go to find and/or submit
 > >PRs.  www.rtems.com has been inaccessible to me all weekend.
 > >Gregm
