Building Tools
Angelo Fraietta
angelo_f at bigpond.com
Tue Feb 25 22:39:38 UTC 2003
I commenced building the tools, however, I have come into an error
I first had to make a soft link to binutils and gcc before moving to the
build, otherwise the configure did not work EG with gcc
Configure, build and install the cross-compiler and libraries
1. Create a directory in which the tools will be built and change
to that directory.
rm -rf build
mkdir build
ln -s gcc-3.2.1 gcc
cd build
2. Configure the compiler and libraries.
../\gcc/configure --target=i386-rtems --prefix=/opt/rtems \
--with-gnu-as --with-gnu-ld --with-newlib --verbose \
--with-system-zlib --disable-nls \
--enable-version-specific-runtime-libs \
--enable-threads=rtems \
--enable-languages=c,c++
The binutils worked fine, however, this was not the case with gcc.
During the build I got the following error
i386-rtems-ar rc ./libgcc.a libgcc/./_muldi3.o libgcc/./_negdi2.o
libgcc/./_lshrdi3.o libgcc/./_ashldi3.o libgcc/./_ashrdi3.o
libgcc/./_ffsdi2.o libgcc/./_clz.o libgcc/./_cmpdi2.o
libgcc/./_ucmpdi2.o libgcc/./_floatdidf.o libgcc/./_floatdisf.o
libgcc/./_fixunsdfsi.o libgcc/./_fixunssfsi.o libgcc/./_fixunsdfdi.o
libgcc/./_fixdfdi.o libgcc/./_fixunssfdi.o libgcc/./_fixsfdi.o
libgcc/./_fixxfdi.o libgcc/./_fixunsxfdi.o libgcc/./_floatdixf.o
libgcc/./_fixunsxfsi.o libgcc/./_fixtfdi.o libgcc/./_fixunstfdi.o
libgcc/./_floatditf.o libgcc/./_clear_cache.o libgcc/./_trampoline.o
libgcc/./__main.o libgcc/./_exit.o libgcc/./_absvsi2.o
libgcc/./_absvdi2.o libgcc/./_addvsi3.o libgcc/./_addvdi3.o
libgcc/./_subvsi3.o libgcc/./_subvdi3.o libgcc/./_mulvsi3.o
libgcc/./_mulvdi3.o libgcc/./_negvsi2.o libgcc/./_negvdi2.o
libgcc/./_ctors.o libgcc/./_divdi3.o libgcc/./_moddi3.o
libgcc/./_udivdi3.o libgcc/./_umoddi3.o libgcc/./_udiv_w_sdiv.o
libgcc/./_udivmoddi4.o libgcc/./_pack_sf.o libgcc/./_unpack_sf.o
libgcc/./_addsub_sf.o libgcc/./_mul_sf.o libgcc/./_div_sf.o
libgcc/./_fpcmp_parts_sf.o libgcc/./_compare_sf.o libgcc/./_eq_sf.o
libgcc/./_ne_sf.o libgcc/./_gt_sf.o libgcc/./_ge_sf.o libgcc/./_lt_sf.o
libgcc/./_le_sf.o libgcc/./_unord_sf.o libgcc/./_si_to_sf.o
libgcc/./_sf_to_si.o libgcc/./_negate_sf.o libgcc/./_make_sf.o
libgcc/./_sf_to_df.o libgcc/./_thenan_sf.o libgcc/./_sf_to_usi.o
libgcc/./_usi_to_sf.o libgcc/./_pack_df.o libgcc/./_unpack_df.o
libgcc/./_addsub_df.o libgcc/./_mul_df.o libgcc/./_div_df.o
libgcc/./_fpcmp_parts_df.o libgcc/./_compare_df.o libgcc/./_eq_df.o
libgcc/./_ne_df.o libgcc/./_gt_df.o libgcc/./_ge_df.o libgcc/./_lt_df.o
libgcc/./_le_df.o libgcc/./_unord_df.o libgcc/./_si_to_df.o
libgcc/./_df_to_si.o libgcc/./_negate_df.o libgcc/./_make_df.o
libgcc/./_df_to_sf.o libgcc/./_thenan_df.o libgcc/./_df_to_usi.o
libgcc/./_usi_to_df.o libgcc/./xp-bit.o libgcc/./unwind-dw2.o
libgcc/./unwind-dw2-fde.o libgcc/./unwind-sjlj.o libgcc/./_eprintf.o
libgcc/./_bb.o libgcc/./__gcc_bcmp.o
make[2]: i386-rtems-ar: Command not found
make[2]: *** [libgcc.a] Error 127
make[2]: Leaving directory `/opt/rtems/tools/build/gcc'
make[1]: *** [stmp-multilib] Error 2
make[1]: Leaving directory `/opt/rtems/tools/build/gcc'
make: *** [all-gcc] Error 2
I had a look through the previous configure and got this -- however I
don't know whether it is relevant:
checking what nm to use... i386-rtems-nm
checking what objdump to use... i386-rtems-objdump
checking assembler alignment features... .p2align including maximum skip
checking assembler subsection support... ../../gcc/gcc/configure:
i386-rtems-nm: command not found
../../gcc/gcc/configure: i386-rtems-nm: command not found
.subsection
I have attached my config script (I also tried it with removing the
first \. i.e ../gcc instead of ../\gcc)
Any suggestions as to what I may be doing wrong
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030226/7a0dfcfd/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20030226/7a0dfcfd/attachment.ksh>
