RPM rebuild made easier?
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Wed Feb 26 20:09:10 UTC 2003
Hi,
we had a discussion about version dependent tool installation
prefixes some weeks ago, and I accepted the reasons why the
RPMs on OARs web server all use the standard prefix
"/opt/rtems". My conclusion was (and is) that rebuilding the
tools (under linux) is not so painful.
Now I have actually (once again) rebuilt the current toolset,
and in the RPM specs found constucts to change the rebuild
process with "--define" statements fromt the RPM command line.
So here is my request: Would it be possible to replace the
"_prefix" definition in the specs from
%define _prefix /opt/rtems
to something like:
%define _prefix %{?prefix:%prefix}%{!?prefix:/opt/rtems}
(Ralf, is this correct? Any improvements possible?)
The anybody who wants to rebuild the toolset simply has to
call RPM as follows:
$ rpm -ba --define 'prefix /opt/rtems/binutils-2.13.2.1-gcc-
3.2.1-newlib-1.11.0' --define 'gnat 0' --define 'gcj 0'
powerpc-rtems-gcc-3.2.1-newlib-1.11.0.spec
No more hacking around inside the specs...
Is it possible to integrate this into the toolse specs?
wkr,
Thomas.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
