Snapshot 20030128 broke my buildt
Wed Feb 26 22:27:33 UTC 2003
Till Straumann wrote:
> I had submitted a fix for this
> PR#340
It is merged on both the release branch and trunk so the next
tarballs will pick it up.
Thanks for the speed Till.
> HTH
> -- Till
> Angelo Fraietta wrote:
> > I am getting the followingh link error when I try to build my exe (the
> > rtems source builds fine)
> > i386-rtems-gcc --pipe -B/opt/rtems/i386-rtems/pc386/lib/ -specs
> > bsp_specs -qrtems   -g -Wall  -O4 -g       -D_E_STL    -I ../../../estl
> > -I ../engine -I ../engineinterface -I ../hal_include -I ../link_driver
> > -I ../../../threads/source -I ../../../mididriver -I
> > ../../../mididriver/hal_rtems       -Wl,-Ttext,0x00100000 -o
> > o-optimize/smart.obj  o-optimize/diags.o o-optimize/rtems_init.o
> > o-optimize/midioutput.o o-optimize/scheduler.o
> > o-optimize/rtems_simulator.o o-optimize/commtasks.o
> > /opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel
> > /opt/rtems/i386-rtems/pc386/lib/no-mp.rel
> > /opt/rtems/i386-rtems/pc386/lib/no-part.rel
> > /opt/rtems/i386-rtems/pc386/lib/no-signal.rel
> > ../engine/o-optimize/sm_engine.a
> > ../engineinterface/o-optimize/sm_engineinterface.a
> > ../link_driver/o-optimize/sm_link_driver.a
> > ../link_driver/hal_rtems/o-optimize/sm_comm.a
> > ../../../threads/source/o-optimize/sm_rtems_active.a
> > ../../../threads/source/hal_rtems/o-optimize/sm_rtems_thread.a
> > ../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -v
> > Reading specs from /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/specs
> > Reading specs from /opt/rtems/i386-rtems/pc386/lib/bsp_specs
> > rename spec cpp to old_cpp
> > rename spec lib to old_lib
> > rename spec endfile to old_endfile
> > rename spec startfile to old_startfile
> > rename spec link to old_link
> > Configured with: ../gcc/configure --target=i386-rtems
> > --prefix=/opt/rtems --with-gnu-as --with-gnu-ld --with-newlib --verbose
> > --with-system-zlib --disable-nls --enable-version-specific-runtime-libs
> > --enable-threads=rtems --enable-languages=c,c++
> > : (reconfigured) ../gcc/configure --target=i386-rtems
> > Thread model: rtems
> > gcc version 3.2.1
> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/collect2 -dc -dp -N -e start -o
> > o-optimize/smart.obj /opt/rtems/i386-rtems/pc386/lib/start.o
> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crti.o
> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtbegin.o
> > -L/opt/rtems/i386-rtems/pc386/lib
> > -L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1
> > -L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib
> > -Ttext 0x00100000 o-optimize/diags.o o-optimize/rtems_init.o
> > ../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -lgcc
> > --start-group -lrtemsbsp -lrtemscpu -lc -lgcc --end-group -T
> > /opt/rtems/i386-rtems/pc386/lib/linkcmds -lgcc
> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtend.o
> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtn.o
> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fdopen.o):
> > In function `_fdopen_r':
> > /opt/rtems/tools/build/i386-rtems/newlib/libc/stdio/../../../../../gcc/newlib/libc/stdio/fdopen.c:67:
> > undefined reference to `_fcntl_r'
> > collect2: ld returned 1 exit status
> > make: *** [o-optimize/smart.exe] Error 1
> > [angelo-Fraiettas-Computer:controller/source/hal_rtems_pc386]
> > angelofraietta%
> > This also happend with the pc386dx build as well as the pc386 build
