Snapshot 20030128 broke my buildt
Wed Feb 26 23:22:23 UTC 2003
Angelo Fraietta wrote:
> Is there anything I can do now?
Download the patch attached to PR340 and apply it. :)
The URL is http://www.oarcorp.com/cgi-bin/gnatsweb.pl
Login as guest with password guest.  If someone knows
how to turn that into a URL, it would be handy. :)
> Joel Sherrill wrote:
> > Till Straumann wrote:
> >> I had submitted a fix for this
> >> PR#340
> > It is merged on both the release branch and trunk so the next
> > tarballs will pick it up.
> > Thanks for the speed Till.
> >> HTH
> >> -- Till
> >> > I am getting the followingh link error when I try to build my exe
> >> > (the
> >> > rtems source builds fine)
> >> > i386-rtems-gcc --pipe -B/opt/rtems/i386-rtems/pc386/lib/ -specs
> >> > bsp_specs -qrtems   -g -Wall  -O4 -g       -D_E_STL    -I
> >> > ../../../estl
> >> > -I ../engine -I ../engineinterface -I ../hal_include -I
> >> > ../link_driver
> >> > -I ../../../threads/source -I ../../../mididriver -I
> >> > ../../../mididriver/hal_rtems       -Wl,-Ttext,0x00100000 -o
> >> > o-optimize/smart.obj  o-optimize/diags.o o-optimize/rtems_init.o
> >> > o-optimize/midioutput.o o-optimize/scheduler.o
> >> > o-optimize/rtems_simulator.o o-optimize/commtasks.o
> >> > /opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel
> >> > /opt/rtems/i386-rtems/pc386/lib/no-mp.rel
> >> > /opt/rtems/i386-rtems/pc386/lib/no-part.rel
> >> > /opt/rtems/i386-rtems/pc386/lib/no-signal.rel
> >> > ../engine/o-optimize/sm_engine.a
> >> > ../engineinterface/o-optimize/sm_engineinterface.a
> >> > ../link_driver/o-optimize/sm_link_dri
> >> > ver.a
> >> > ../link_driver/hal_rtems/o-optimize/sm_comm.a
> >> > ../../../threads/source/o-optimize/sm_rtems_active.a
> >> > ../../../threads/source/hal_rtems/o-optimize/sm_rtems_thread.a
> >> > ../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -v
> >> > Reading specs from /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/specs
> >> > Reading specs from /opt/rtems/i386-rtems/pc386/lib/bsp_specs
> >> > rename spec cpp to old_cpp
> >> > rename spec lib to old_lib
> >> > rename spec endfile to old_endfile
> >> > rename spec startfile to old_startfile
> >> > rename spec link to old_link
> >> > Configured with: ../gcc/configure --target=i386-rtems
> >> > --prefix=/opt/rtems --with-gnu-as --with-gnu-ld --with-newlib
> >> > --verbose
> >> > --with-system-zlib --disable-nls
> >> > --enable-version-specific-runtime-libs
> >> > --enable-threads=rtems --enable-languages=c,c++
> >> > : (reconfigured) ../gcc/configure --target=i386-rtems
> >> > --verbose
> >> > --with-system-zlib --disable-nls --enable-versi
> >> > Thread model: rtems
> >> > gcc version 3.2.1
> >> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/collect2 -dc -dp -N -e
> >> > start -o
> >> > o-optimize/smart.obj /opt/rtems/i386-rtems/pc386/lib/start.o
> >> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crti.o
> >> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtbegin.o
> >> > -L/opt/rtems/i386-rtems/pc386/lib
> >> > -L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1
> >> > -L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib
> >> > -Ttext 0x00100000 o-optimize/diags.o o-optimize/rtems_init.o
> >> > m_engine.a
> >> > ../link_driver/o-optimize/sm_link_driver.a
> >> > -lgcc
> >> > --start-group -lrtemsbsp -lrtemscpu -lc -lgcc --end-group -T
> >> > /opt/rtems/i386-rtems/pc386/lib/linkcmds -lgcc
> >> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtend.o
> >> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtn.o
> >> > /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fdopen.o):
> >> > In function `_fdopen_r':
> >> > /opt/rtems/tools/build/i386-rtems/newlib/libc/stdio/../../../../../gcc/newlib/libc/stdio/fdopen.c:67:
> >> > undefined reference to `_fcntl_r'
> >> > collect2: ld returned 1 exit status
> >> > make: *** [o-optimize/smart.exe] Error 1
> >> > [angelo-Fraiettas-Computer:controller/source/hal_rtems_pc386]
> >> > angelofraietta%
> >> > This also happend with the pc386dx build a
> >> > s well as the pc386 build
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
