Snapshot 20030128 broke my buildt
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Feb 27 05:05:02 UTC 2003
Am Don, 2003-02-27 um 05.29 schrieb Angelo Fraietta:
> Ralf Corsepius wrote:
> > Am Mit, 2003-02-26 um 22.46 schrieb Angelo Fraietta:
> > > I am getting the followingh link error when I try to build my exe (the
> > > rtems source builds fine)
> > > i386-rtems-gcc --pipe -B/opt/rtems/i386-rtems/pc386/lib/ -specs
> > > bsp_specs -qrtems   -g -Wall  -O4 -g       -D_E_STL    -I ../../../estl
> > > -I ../engine -I ../engineinterface -I ../hal_include -I ../link_driver
> > > -I ../../../threads/source -I ../../../mididriver -I
> > > ../../../mididriver/hal_rtems       -Wl,-Ttext,0x00100000 -o
> > > o-optimize/smart.obj  o-optimize/diags.o o-optimize/rtems_init.o
> > > o-optimize/midioutput.o o-optimize/scheduler.o
> > > o-optimize/rtems_simulator.o o-optimize/commtasks.o
> > > /opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel
> > > /opt/rtems/i386-rtems/pc386/lib/no-mp.rel
> > > /opt/rtems/i386-rtems/pc386/lib/no-part.rel
> > > /opt/rtems/i386-rtems/pc386/lib/no-signal.rel
> > > ../engine/o-optimize/sm_engine.a
> > > ../engineinterface/o-optimize/sm_engineinterface.a
> > > ../link_driver/o-
> > > optimize/sm_link_driver.a
> > > ../link_driver/hal_rtems/o-optimize/sm_comm.a
> > > ../../../threads/source/o-optimize/sm_rtems_active.a
> > > ../../../threads/source/hal_rtems/o-optimize/sm_rtems_thread.a
> > > ../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -v
> > Where does this -lstdc++ come from?
> > Linking c++ applications using
> > gcc <args> -lstdc++
> > is wrong. You must use
> > g++ <args>
> > instead.
> This has been in my project since Oct 2000
> I added
> LINK_LIBS += -lstdc++
> to my project makefile
> Is this changed now?
This is a general behavioral change in gcc.
It has been recommended to link c++-applications with g++ for several
years (Approximately since the egcs day), but using gcc to link c++ has
continued to work, more or less at random, on some targets.
Nowadays you are supposed to apply g++, because linking c++ with gcc
already doesn't work on some targets and will almost 100% certainly stop
working in future releases of gcc.
Ralf
