Snapshot 20030128 broke my buildt
Angelo Fraietta angelo_f at bigpond.com
Fri Feb 28 00:36:55 UTC 2003
It appears to be very broken
I ran some of the samples with the following results:
    ticker ***********************
    - I get a message on the console that clock tick test is starting
and then the machine reboots
    unlimited *************************
    I get the message
    TEST1: auto-extend disabled
    TEST1: creating task 'aa00', number = 0, ide = 0a010002, starting
    The application seems frozen now with a cursor blinking at one space
after the comma on the last line
    paranoia *************************
    passes test
Could someone send me a copy of built examples of ticker and unlimited
for a pc386dx build so I can eliminate or determine the problem is at my
end?
Thanks
Angelo Fraietta wrote:
> My build is broken in that the application can no longer start.
> Is suspect that the problem may be in the static variable
> initialisers, however, I am unsure.
> My device drivers are getting initialised (I can see this on the console)
> however I get an exception error
> exception 6 caught
> This ocurrs before a printf statement I placed at the start of r Init
> I also commented out all the code in the Init function and still got
> the same error.
> I removed nearly all of my code and the application initialised
> Init is in a cpp module which is being executed
> I ahve also noticed that my app is about 25% larger than it used to be.
> Any suggestions?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
