U-Boot booting RTEMS
Erwin Rol
erwin at muffin.org
Fri Feb 28 15:05:03 UTC 2003
OK the patch to U-Boot should show up on the public CVS in the next
couple of days. U-Boot passes its info structure in R3 (PPC only at the
moment, i have no other hardware) and the BSP should copy that
information very early, i do that in the start.S and use a tuned U-Boot
header file to get the structure layout and size.
- Erwin
On Thu, 2003-02-27 at 18:21, emanuel stiebler wrote:
> Erwin Rol wrote:
> > Hey all,
> > I dunno if anybody else is already using U-Boot( AKA PPCBoot ) with
> > RTEMS, but i made a small patch for U-Boot (which i will submit shortly
> > to the U-Boot maintainers ) that give mkimage the posibility to create
> > gzipped RTEMS images, and boot them. I pass the U-Boot config structure
> > in R3 , to use this structure one needs a tweaked header from U-boot,
> > the structure is depended on what CPU is used, it is very simple though,
> > and should not be hard to integrate in the BSP.
> > If there is any interest i can make patches for both RTEMS and U-Boot so
> > that ppl can try it before those patches get accepted by the developers
> > of U-Boot/RTEMS.
> Interest for sure !
> However, I'm still fighting with my mpc8245 based hardware ;-)
> (using u-boot)
> cheers
Dipl.-Ing. Erwin Rol - Software Engineering
tel: +49-(0)8024-479377 gsm: +49-(0)171-6929198 fax: +49-(0)8024-479379
email: erwin at muffin.org
Type: application/pgp-signature
Desc: This is a digitally signed message part
URL: <http://lists.rtems.org/pipermail/users/attachments/20030228/c11b6be9/attachment.bin>
