code size latest snapshop versus 200206
Peter Mueller peter.o.mueller at gmx.de
Fri Feb 28 19:47:24 UTC 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Sorry for the delayed answer. I use a modified efi332 with networking
(cs8900) and ide interface.
Latest tool set from the CD directory. I can't remember to tool versions I
used for the old build - already deleted :-(
I have used the diffcalc script. Here are some major differences:
_vfiprintf_r C 2166 2624
_vfprintf_r C 4166 4622
avl_search_for_sync N 0 174
_CORE_mutex_Seize_interrupt_trylock N 0 244
data.0 N 0 512
kernel_sysctlbyname N 0 130
kern_mib.c N 0 0
kern_sysctl.c N 0 0
last_adjusted_timeout.0 N 0 4
last_zeroed.0 N 0 4
__lc_ctype N 0 12
libgcc2.c N 0 0
libgcc2.c N 0 0
libgcc2.c N 0 0
link_ascii N 0 118
__locale_charset N 0 14
m68kidle.c N 0 0
machine N 0 7
memfile_check_rmnod N 0 80
_mktm_r N 0 1188
mktm_r.c N 0 0
__mlocale_changed N 0 4
_mrt_ioctl N 0 4
mtutab.0 N 0 48
name2oid N 0 248
newoid.0 N 0 4
__nlocale_changed N 0 4
null_local_table.0 N 0 4
null_sdl.0 N 0 20
object.2 N 0 24
objectgetnoprotection.c N 0 0
_Objects_Get_no_protection N 0 44
old_cnt.3 N 0 4
old_mono_secs.1 N 0 4
osrelease N 0 10
ostype N 0 6
p.0 N 0 0
p05.0 N 0 12
part_desc.3 N 0 4
part_table.1 N 0 4
_PathLocale N 0 4
p_environ N 0 4
_POSIX_Objects N 0 36
prev_bps.1 N 0 4
prev_seconds_since_epoch.2 N 0 4
prev_tzenv N 0 4
putchar N 0 24
putchar.c N 0 0
_putchar_r N 0 114
ret.0 N 0 18
rnd.0 N 0 4
_RTEMS_Allocator_Mutex N 0 4
rtems_bsdnet_bootp_cmdline N 0 4
_RTEMS_Objects N 0 40
seconds_since_epoch.3 N 0 4
__set_domain_set_sym_inetdomain N 0 4
__set_domain_set_sym_routedomain N 0 4
__set_sysctl_set_sym_sysctl___kern N 0 4
__set_sysctl_set_sym_sysctl___kern_maxsockbuf N 0 4
__set_sysctl_set_sym_sysctl___kern_osrelease N 0 4
__set_sysctl_set_sym_sysctl___kern_osrevision N 0 4
__set_sysctl_set_sym_sysctl___kern_ostype N 0 4
__set_sysctl_set_sym_sysctl___kern_sockbuf_waste_factor N 0 4
__set_sysctl_set_sym_sysctl___kern_somaxconn N 0 4
__set_sysctl_set_sym_sysctl___net N 0 4
__set_sysctl_set_sym_sysctl___net_inet N 0 4
__set_sysctl_set_sym_sysctl___net_inet_icmp N 0 4
__set_sysctl_set_sym_sysctl___net_inet_icmp_bmcastecho N 0 4
__set_sysctl_set_sym_sysctl___net_inet_icmp_maskrepl N 0 4
__set_sysctl_set_sym_sysctl___net_inet_icmp_stats N 0 4
__set_sysctl_set_sym_sysctl___net_inet_igmp N 0 4
__set_sysctl_set_sym_sysctl___net_inet_igmp_stats N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_accept_sourceroute N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_forwarding N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_intr_queue_drops N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_intr_queue_maxlen N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_portrange N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_portrange_first N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_portrange_hifirst N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_portrange_hilast N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_portrange_last N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_portrange_lowfirst N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_portrange_lowlast N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_redirect N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_rtexpire N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_rtmaxcache N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_rtminexpire N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_sourceroute N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_subnets_are_local N 0 4
__set_sysctl_set_sym_sysctl___net_inet_ip_ttl N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_always_keepalive N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_keepidle N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_keepinit N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_keepintvl N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_log_in_vain N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_mssdflt N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_pcblist N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_recvspace N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_sendspace N 0 4
__set_sysctl_set_sym_sysctl___net_inet_tcp_stats N 0 4
__set_sysctl_set_sym_sysctl___net_inet_udp N 0 4
__set_sysctl_set_sym_sysctl___net_inet_udp_checksum N 0 4
__set_sysctl_set_sym_sysctl___net_inet_udp_log_in_vain N 0 4
__set_sysctl_set_sym_sysctl___net_inet_udp_maxdgram N 0 4
__set_sysctl_set_sym_sysctl___net_inet_udp_pcblist N 0 4
__set_sysctl_set_sym_sysctl___net_inet_udp_recvspace N 0 4
__set_sysctl_set_sym_sysctl___net_inet_udp_stats N 0 4
__set_sysctl_set_sym_sysctl___net_link N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether_inet N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether_inet_host_down_time N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether_inet_max_age N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether_inet_maxtries N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether_inet_proxyall N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether_inet_prune_intvl N 0 4
__set_sysctl_set_sym_sysctl___net_link_ether_inet_useloopback N 0 4
__set_sysctl_set_sym_sysctl___net_link_generic N 0 4
__set_sysctl_set_sym_sysctl___net_routetable N 0 4
__set_sysctl_set_sym_sysctl___sysctl N 0 4
__set_sysctl_set_sym_sysctl___sysctl_debug N 0 4
__set_sysctl_set_sym_sysctl___sysctl_name2oid N 0 4
__set_sysctl_set_sym_sysctl___sysctl_name N 0 4
__set_sysctl_set_sym_sysctl___sysctl_next N 0 4
__set_sysctl_set_sym_sysctl___sysctl_oiddescr N 0 4
__set_sysctl_set_sym_sysctl___sysctl_oidfmt N 0 4
sin.2 N 0 16
skip_options N 0 172
_sscanf_r N 0 88
__start_set_sysctl_set N 0 0
__stop_set_sysctl_set N 0 0
strlcpy N 0 64
strlcpy.c N 0 0
strtof N 0 40
_strtoll_r N 0 480
strtoll_r.c N 0 0
_strtoull_r N 0 444
strtoull_r.c N 0 0
__svfscanf_r N 0 2870
__swbuf N 0 210
sysctl N 0 108
__sysctl N 0 148
sysctl_add_oid N 0 484
sysctl__children N 0 4
sysctl_ctx_entry_add N 0 90
sysctl_ctx_entry_del N 0 98
sysctl_ctx_entry_find N 0 44
sysctl_ctx_free N 0 178
sysctl_ctx_init N 0 22
sysctl_find_oid N 0 136
sysctl_handle_int N 0 100
sysctl_handle_long N 0 86
sysctl_handle_opaque N 0 178
sysctl_handle_string N 0 166
sysctl___kern N 0 44
sysctl__kern_children N 0 4
sysctl___kern_maxsockbuf N 0 44
sysctl___kern_osrelease N 0 44
sysctl___kern_osrevision N 0 44
sysctl___kern_ostype N 0 44
sysctl___kern_sockbuf_waste_factor N 0 44
sysctl___kern_somaxconn N 0 44
sysctl___net N 0 44
sysctl__net_children N 0 4
sysctl___net_inet N 0 44
sysctl__net_inet_children N 0 4
sysctl___net_inet_icmp N 0 44
sysctl___net_inet_icmp_bmcastecho N 0 44
sysctl__net_inet_icmp_children N 0 4
sysctl___net_inet_icmp_maskrepl N 0 44
sysctl___net_inet_icmp_stats N 0 44
sysctl___net_inet_igmp N 0 44
sysctl__net_inet_igmp_children N 0 4
sysctl___net_inet_igmp_stats N 0 44
sysctl___net_inet_ip N 0 44
sysctl___net_inet_ip_accept_sourceroute N 0 44
sysctl__net_inet_ip_children N 0 4
sysctl___net_inet_ip_forwarding N 0 44
sysctl___net_inet_ip_intr_queue_drops N 0 44
sysctl___net_inet_ip_intr_queue_maxlen N 0 44
sysctl___net_inet_ip_portrange N 0 44
sysctl__net_inet_ip_portrange_children N 0 4
sysctl___net_inet_ip_portrange_first N 0 44
sysctl___net_inet_ip_portrange_hifirst N 0 44
sysctl___net_inet_ip_portrange_hilast N 0 44
sysctl___net_inet_ip_portrange_last N 0 44
sysctl___net_inet_ip_portrange_lowfirst N 0 44
sysctl___net_inet_ip_portrange_lowlast N 0 44
sysctl___net_inet_ip_redirect N 0 44
sysctl___net_inet_ip_rtexpire N 0 44
sysctl___net_inet_ip_rtmaxcache N 0 44
sysctl___net_inet_ip_rtminexpire N 0 44
sysctl___net_inet_ip_sourceroute N 0 44
sysctl___net_inet_ip_subnets_are_local N 0 44
sysctl___net_inet_ip_ttl N 0 44
sysctl___net_inet_tcp N 0 44
sysctl___net_inet_tcp_always_keepalive N 0 44
sysctl__net_inet_tcp_children N 0 4
sysctl___net_inet_tcp_keepidle N 0 44
sysctl___net_inet_tcp_keepinit N 0 44
sysctl___net_inet_tcp_keepintvl N 0 44
sysctl___net_inet_tcp_log_in_vain N 0 44
sysctl___net_inet_tcp_mssdflt N 0 44
sysctl___net_inet_tcp_pcblist N 0 44
sysctl___net_inet_tcp_recvspace N 0 44
sysctl___net_inet_tcp_sendspace N 0 44
sysctl___net_inet_tcp_stats N 0 44
sysctl___net_inet_udp N 0 44
sysctl___net_inet_udp_checksum N 0 44
sysctl__net_inet_udp_children N 0 4
sysctl___net_inet_udp_log_in_vain N 0 44
sysctl___net_inet_udp_maxdgram N 0 44
sysctl___net_inet_udp_pcblist N 0 44
sysctl___net_inet_udp_recvspace N 0 44
sysctl___net_inet_udp_stats N 0 44
sysctl_net_ipport_check N 0 300
sysctl___net_link N 0 44
sysctl__net_link_children N 0 4
sysctl___net_link_ether N 0 44
sysctl__net_link_ether_children N 0 4
sysctl___net_link_ether_inet N 0 44
sysctl__net_link_ether_inet_children N 0 4
sysctl___net_link_ether_inet_host_down_time N 0 44
sysctl___net_link_ether_inet_max_age N 0 44
sysctl___net_link_ether_inet_maxtries N 0 44
sysctl___net_link_ether_inet_proxyall N 0 44
sysctl___net_link_ether_inet_prune_intvl N 0 44
sysctl___net_link_ether_inet_useloopback N 0 44
sysctl___net_link_generic N 0 44
sysctl__net_link_generic_children N 0 4
sysctl___net_routetable N 0 44
sysctl__net_routetable_children N 0 4
sysctl_new_kernel N 0 72
sysctl_new_user N 0 72
sysctl_old_kernel N 0 110
sysctl_old_user N 0 108
sysctl_register_all N 0 38
sysctl_register_oid N 0 206
sysctl_remove_oid N 0 302
sysctl_root N 0 158
sysctl___sysctl N 0 44
sysctl__sysctl_children N 0 4
sysctl_sysctl_debug N 0 18
sysctl___sysctl_debug N 0 44
sysctl_sysctl_debug_dump_node N 0 266
sysctl_sysctl_name2oid N 0 178
sysctl___sysctl_name2oid N 0 44
sysctl_sysctl_name N 0 310
sysctl___sysctl_name N 0 44
sysctl__sysctl_name_children N 0 4
sysctl___sysctl_next N 0 44
sysctl_sysctl_next N 0 96
sysctl__sysctl_next_children N 0 4
sysctl_sysctl_next_ls N 0 216
sysctl___sysctl_oiddescr N 0 44
sysctl_sysctl_oiddescr N 0 98
sysctl__sysctl_oiddescr_children N 0 4
sysctl_sysctl_oidfmt N 0 128
sysctl___sysctl_oidfmt N 0 44
sysctl__sysctl_oidfmt_children N 0 4
sysctl_unregister_oid N 0 50
sysctl_wire_old_buffer N 0 40
tcp_pcblist N 0 470
_Thread_Get N 0 122
_Thread_Get N 0 122
_Thread_Get N 0 122
_Thread_Get N 0 122
_Thread_Get N 0 122
_Thread_Get N 0 122
_Thread_Get N 0 122
_Thread_Get N 0 122
_Thread_Get N 0 122
_timezone N 0 4
txt.0 N 0 28
__tzcalc_limits N 0 586
__tz_lock N 0 8
tzlock.c N 0 0
_tzname N 0 8
__tzname_dst N 0 11
__tzname_std N 0 11
__tznorth N 0 4
__tzrule N 0 52
_tzset_r N 0 1142
tzset_r.c N 0 0
__tz_unlock N 0 8
__tzyear N 0 4
__udivdi3 N 0 28
__udivmoddi4 N 0 370
udp_pcblist N 0 398
__umoddi3 N 0 38
userland_sysctl N 0 380
vfcntl N 0 382
vfscanf N 0 76
_vfscanf_r N 0 30
_vprintf_r N 0 32
_vsprintf_r N 0 76
wbuf.c N 0 0
zeroes.1 N 0 16
zeroes.1 N 0 16
Does this help?
Peter
On Thu, 27 Feb 2003 08:37:50 -0600
Joel Sherrill <joel.sherrill at OARcorp.com> wrote:
> Chris Johns wrote:
> > Till Straumann wrote:
> > > It's not clear who is really responsible for the net increase
> > > as some things got bigger and some new symbols appear but other
> > > symbols shrunk or disappeared.
> > > There is also noticable fluctuation among small items.
> > I agree. Most items are small excluding the _vfiprintf_r/_vfprintf_r
> > etc. Some call must have been added to bring these in.
> > Not sure why the change has happened.
> If the references to _vfiprintf_r/_vfprintf_r are new, then
> please use the -Map option to ld to find out what is rerfercing it
> and forcing it in.
> I am in the middle of building tools so am not in a good position to
> check other targets.  What BSP are you using Peter?  If not a PPC one,
> then it is likely some shared support code and we need to find it and
> reduce the dependencies.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.7 (GNU/Linux)
iD8DBQE+X7zMUzCcwYQMTJoRAqA1AJ9y1FJm++fx0FygGW45QonH1hHG8QCgtZfO
iYBS8FosAPk/YhF3o48Ek5w=
=bYiz
-----END PGP SIGNATURE-----
