My periodic bark at auto "tools" 2003/1 edition (was Re:rtems-ss-20030128)
Jerry Needell
jerry.needell at unh.edu
Mon Feb 3 20:04:07 UTC 2003
Thomas Doerfler wrote:
> Hello Ralf,
>>Am Mon, 2003-02-03 um 16.15 schrieb Thomas Doerfler:
>>>Hello,
>>>... many lines snipped...
... many more lines snipped
> Another point: whenever somebody mentions the need to install
> multiple toolset versions on the same machine, he/she gets the
> answer "rebuild the toolset with different prefixes", well
> this once again leads to having toolset-dependent installation
> directories, and that's exactly what I would like to have.
> Maybe the naming scheme mentioned above is not the best one,
> maybe it would be better to couple the toolset install
> directory name to the RTMES snapshot version or something like
> that, but I think ANY version-dependent installation dirctory
> in the standard RPMs would be better than the current choices,
> that are:
> A:) Install only ONE toolset on a certain machine (and
> deinstall/install another toolset when you switch to a
> different RTEMS snapshot)
> or
> B:) Rebuild the RPMs (which is really easy, I like it now) and
> apply your own home-brewn naming scheme to the installation
> prefix.
> Any other opinions on this discussion?
I have had to deal with several different pre-compilled installations at
various times and found that the following worked well for me:
-install version A in /opt/rtems
-rename /opt/rtems to /opt/rtems-A
- install verion B in /opt/rtems
- rename /opt/rtems to /opt/rtems-B
-make a symbolic link from rtems-A or rtems-B to /opt/rtems depending on
which installation I want to use at the time.
-- Jerry
> wkr,
> Thomas.
> P.S.: Ralf, I really want to thank you for the work you do for
> RTEMS, I don't understand all the ideas behind
> autoconf/automake, but I am sure it keeps the RTEMS source
> tree manageable.
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
_______________________________________________________________________
Jerry Needell | Internet: jerry.needell at unh.edu
Space Science Center/Morse Hall | Voice: (603) 862 2732
University Of New Hampshire | FAX: (603) 862 0311
Durham, NH 03824 |
