Newbie -- Accessing Hardware Ports
Don donp_news at glasscity.net
Tue Feb 4 20:49:08 UTC 2003
Till,
Looked at youir previous message also.  Yup, the '-' was a case of
being a typo in creating the message.  Unfortunatley, my development
machine is not hooked up to this machine so cut 'n paste is a bit of a
chore.
Also, I got a response form another individual who pointed out the
missing wait loop after the second write to the LED register.  Again a
typo.
See my embedded comment regarding the PCI space issue.
Thanks!!
Don
> A followup to my previous message.
> I just had a quick look at your BSP. It seems that the on-board
> registers are attached to PCI_IO space starting at port 0.
> Hence, you should be able to access your LEDs using the
> outport_byte(0x860, (unsigned char)VALUE)
> macro who does the necessary address translation (and IO barrier
> instruction [this is not strictly needed for your LED example]) for
you.
Interesting!  According to the PPC2A manual, the port address (0x0860)
is in "system memory space" (0x00000000 to 0x7FFFFFFF) and under the
heading of "PCI Address Range" it says "No PCI cycle".  Looks like
there is a disconnect between the BSP and PPC2A documentation.  BUT,
this gives me the clue I need to chase down the problem!!
> -- Till
> Don wrote:
> > Okay, I have managed to get 'hello world' to work under both psim
and
> > on a PPC2A using the ppcn_60x BSP.  Now I am trying to branch out
and
> > exercise the board by flashing some LEDs.  Code snip looks
something
> > like:
> >     volatile unsigned8 *pLED_Control;
> >     pLED_Control = (unsigned8 *) 0x00000860;
> >     while(1)
> >         *pLED_Control = 0x0F;
> >         /**  wait loop  **/
> >         *pLED_Control - 0x00;  /** LEDs should blink on & off  **/
> > Unfortunately, nothing happens.  I have also tried reading some
board
> > configuration locations (8-bit) and got back values that are no
where
> > near what they should be.
> > Now I have concluded the problem is one of the following, but have
not
> > been able to find documentation to support or refute the position:
> > 1)  RTEMS does not allow direct manipulation of hardware ports via
> > pointers.  (But there has got to be a way around this as the COM
port
> > works.)
> > 2)  That region of memory is being cached.  In which case I need to
> > figure out how to access the hardware registers to keep that region
> > from being cashed.
> > 3)  I have screwed up basic C code.
> > 4)  There is a board configuration problem.
> > Anybody willing to hazard a guess as to which is the most likely
> > problem?
> > Thanks!!
> > Don
> > www.dynamic-controls-inc.com
