Help With coldfire needed
Fabrizio Pirovano
rtems.thysys at tiscalinet.it
Fri Feb 7 14:04:35 UTC 2003
Hi all,
from my application on coldfire targets I have evidence that gcc3.2.1 is
affected by a bug similar to PR8309 (if I compile my code with optimization level> 0).
I obtain correct code (and all work fine) if I use the option -O4 -fno-force-mem. (O4 or O1, O2 O3)
I am trying to investigate the problem:
from a C code as
short I
for(I=0; I<xx ;I++)
but located inside a function that use many dinamic variables,
I obtain from gcc an assembler code as:
move. w d0, 0x10(a6) (I=0 ; I is declared as short
and 0x10(a6) is his place)
moveq.l #1,d5 (I++)
add.l d5,0x10(a6) (!!!!! : correct code is add.w d5,0x10(a6) )
Best regards
Fabrizio Pirovano
URL: <http://lists.rtems.org/pipermail/users/attachments/20030207/435bf6db/attachment-0001.html>
