Makefile.am question
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Sat Feb 8 01:03:47 UTC 2003
Am Fre, 2003-02-07 um 23.53 schrieb Till Straumann:
> I'm in the process of brining my BSP in sync with the latest snapshot's
> (auto)make files.
> I'm sure this has been asked before:
> What is the difference between TMPINSTALL_FILES and PREINSTALL_FILES?
OK, I'll try to explain:
When building RTEMS, several files and directories get installed to
various places within the build tree at different stages of the build
process, during execution of different make targets.
These are
make preinstall
make all
make install
"make preinstall" is a make target that is internally triggered _before_
anything is _compiled_ ("preinstallation"). The files getting installed
during "make preinstall" are contained in PREINSTALL_FILES, typically
these are headers and very few other files (bsp_specs, linker scripts).
"make install" is the make target, which installs files to their final
destination out of the build directories. These are handled by standard
automake rules.
"make all" is them make target, which builds/compiles everything. Files
supposed to get installed into the build directory _after_ _compilation_
are contained in TMPINSTALL_FILES.
> The powerpc/shared/motorola_powerpc BSP who I am using as a reference
> seems to make inconsistent
Not unlikely.
> (maybe the logic behind it is just too
> obscure for me to guess) use of both of them. Some Makefile.am use
> TMPINSTALL_FILES some use PREINSTALL_FILES to get headers installed
> into the build area... ??
Basically, there is nothing wrong in using both.
Generally, PREINSTALL_FILES should be avoided whenever possible in favor
TMPINSTALL_FILES, because preinstallation leads program authors to be
careless about modular issues and can introduce severe modular problems.
Ralf
