Why _ThreadProcessSignalsFromIrq() in new exception processing?
Valette Eric
eric.valette at free.fr
Mon Feb 10 16:38:53 UTC 2003
Sergei Organov wrote:
> Where _ThreadProcessSignalsFromIrq currently does basically the same thing as
> the _Thread_Dispatch would do if no context switch is necessary, so from
> functional point of view it could be considered as an optimized version of
> _Thread_Dispatch.
Yes it is a kind of optmisation...
>>From the point of view of observable behavior, there are two differences
> between these two methods (differences between _Thread_Dispatch and
> _ThreadProcessSignalsFromIrq aside):
> D1. The latter method always stores the whole (exception) context before
> calling _ThreadProcessSignalsFromIrq.
But only on a path that is documented to be very unfrequent (send a
signal to myself from ISR)
> D2. The latter method fails to reset _ISR_Signals_to_thread_executing to FALSE
> if _Context_Switch_necessary is non-zero.
But do you have executed the post switch code on the right thread in
that case? I guess will be executed once the thread is resumed but did
not read the code yet to be affirmative...
> These differences lead to the following questions:
> 1. Is the whole (exception) context is *strictly required* at the call to
> _Thread_Dispatch when _ISR_Signals_to_thread_executing is non-zero from the
> point of view of correct behavior of the rest of RTEMS (including POSIX
> signals and Ada runtime)?
strictly speaking, you do not need to push a context in current rtems
code without some other code I never posted (beginning of kernel
debugger). But again this path is so infrequent that you can forget it
as far as performance are concerned...
> 2. Should FPU context be stored along with the whole (exception) context?
This can be deffered until you execute some floating point instruction...
> 3. Is the difference (D2) a bug? If yes, the bug in the former code or in
> the later?
Good question!!! I think the later has a bug i should clear it also :-(
BTW : the clearing of_ISR_Signals_to_thread_executing should be done
inside the _Thread_Dispatch to avoid errors like this one...
__
/ ` Eric Valette
/-- __ o _. 6 rue Paul Le Flem
(___, / (_(_(__ 35740 Pace
Tel: +33 (0)2 99 85 26 76 Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
