Default POSIX thread attributes?
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Tue Feb 11 17:39:12 UTC 2003
Am Die, 2003-02-11 um 19.16 schrieb Vladimir Nesic:
> On Tuesday 11 February 2003 16:47, Joel Sherrill wrote:
> > gregory.menke at gsfc.nasa.gov wrote:
> > > Vladimir Nesic writes:
> > > > Current implementation of pthreads has a strange default
> > > > attribute set, which is not documented, and it took me almost a
> > > > whole month to find out why an app that worked on Linux stopped
> > > > working on RTEMS.
> > > These kinds of bugs can be <very> hard to track down on any
> > > operating system. If you rely on default pthread behavior, you're
> > > going to have lots of problems. The pthread interface kind of
> > > sucks in general- its advantage is its sort of portable.
> > The standard does not specify the default attributes as I recall. If
> > there is some piece of standard documentation RTEMS does not adhere
> > to, file a PR.
> > Otherwise, this falls into the "POSIX didn't cover this" category.
> OK, I have learnd my lesson, but I don't have POSIX standard, so I had
> to relay on docs from RTEMS and LINUX. Since RTEMS doesn't say anything
> about it, a guessed that LINUX docs apply :(
One valuable source of information is the OpenGroups online
publications, in particular this document (aka. SUSv3)
http://www.opengroup.org/onlinepubs/007904975/
Ralf
