build & c tools
Paul Whitfield paulw at microsol.iinet.net.au
Wed Feb 12 10:02:13 UTC 2003
Salman wrote:
> I'm using standard gnu build programs
> (ie automake-1.72, autconf-2.57, aclocal-1.72)
> not the rtems ones (eg automake-rtems-automake-1.7.2)
> are they any different ??
> furthermore, should the c-tools be updated if one wants to build the latest rtems snapshot?
> (i'm still using c-tools from rtems-4.5.0 decade)
Hi Salman,
Yes!
You must _definitely_ use up-to date tools to build the newer snapshots
(and less obviously you must use out-of-date tools to build out-of-date
releases!)
Generally the best idea is to get the c-tools from the same release
directory as the snap shot you are trying to build.
Best regards
Paul
