Powerpc IRQ handling breaks strict EABI compliance
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Feb 12 21:53:44 UTC 2003
Till Straumann wrote:
> gregory.menke at gsfc.nasa.gov wrote:
> > till writes:
> > > >>>Sergei Organov wrote:
> > > >>>>Till Straumann <strauman at SLAC.Stanford.EDU> writes:
> > > >>>>>OK, I fixed the motorola/shared BSP to not clobber R2/R13 anymore.
> > > >>>>>However, the question remains:
> > > >>>>> - who is responsible for the setup (calling __eabi()) ?
> > > >>>>> RTEMS or application code?
> > > >>>>It's main() that when compiled with corresponding gcc switches automatically
> > > >>>>invokes __eabi(). It basically only setups R2/R13. BTW, R13 is being used even
> > > >>>>without EABI -- R13 usage is part of SYSV ABI which EABI is derived from.
> > > >>>>This brings another interesting problem. In older days of RTEMS the 'main' was
> > > >>>>part of RTEMS, not the part of application code, so it was invoked very early
> > > >>>>and thus all RTEMS/BSP initialization went after __eabi() has been called.
> > > >>>>AFAIK, now situation is different and __eabi() will be invoked too late. It
> > > >>>>means that RTEMS startup code should invoke __eabi() (or setup R13/R2 itself)
> > > >>>>for things to work correctly as C startup/initialization code compiled for
> > > >>>>SYSV ABI/EABI will already rely on correct values in R2/R13.
> > > >>>RTEMS now ensures that the first thread to execute invokes the
> > > >>>appropriate
> > > >>>routine for that gcc target to run global constructors. The
> > > >>>powerpc-rtems
> > > >>>gcc target is noted as being an init/fini target so it will call
> > > >>>_init().
> > > >>OK, I saw that bsp_specs have been updated to include crtbegin/crtend.
> > > >>However, how do you prevent from initialization happening twice if
> > > >>the user uses 'main'?
> > > >My memory is that the __init functions have a boolean variable that
> > > >say they have been executed already.
> > > I disassembled some code and it doesn't look like there is such a flag.
> > > __eabi() implements
> > > such a guard, however and so does gcc's 'main' header (on architectures
> > > who don't have
> > > ..init/.fini sections) before calling __init(). (I still could be wrong...)
> > The interlock can be seen in _Thread_Handler at about line 111,
> > score/cpu/threadhandler.c, rtems-ss-20030128
> > As implemented, the init task calls the constructors just before
> > jumping to userspace. Once init has called _init_fini, the flag skips
> > future invocations for all tasks created later on.
> Yes, but on PPC this behavior is still wrong (the _Thread_Handler should
> invoke __eabi(), not __init9) on PPC-eabi):
> a) __eabi() does other initialization before calling __init()
> b) if the user (e.g. by means of providing a 'main' [who
> implicitely calls __eabi()]) later calls __eabi(), __init()
> will still be executed twice, because __init() has no guarding
> flag and __eabi() doesn't care about the one private to the
> _Thread_Handler
I agree with the analysis but don't see any indication that gcc tells
us if -meabi or -mno-eabi is in use. DO you have a simple program that
I can compile with powerpc-eabi-gcc and see what it does by comparison?
It is probably trivial to conditionally compile to make the PPC call
__eabi() instead of __init() if we know when precisely to do it.
> -- Till
> > The interlock logic seems a little tortured, but I imagine there is or
> > was a reason for it...
> > __USE_MAIN__ can be made to work, init_fini seems the more current
> > approach.
> > Gregm
joel at OARcorp.com On-Line Applications Research
