Powerpc IRQ handling breaks strict EABI compliance
Till Straumann
strauman at SLAC.Stanford.EDU
Wed Feb 12 22:45:49 UTC 2003
Joel.
>>I agree with the analysis but don't see any indication that gcc tells
>>us if -meabi or -mno-eabi is in use. DO you have a simple program that
>>I can compile with powerpc-eabi-gcc and see what it does by comparison?
> I have a simple program "main(){}". It calls __eabi() regardless of
> how that switch is set.
Yes, we all found that - it's not clear though if this is a bug or a
feature. Note that I also checked against linker magic (the linker
could theoretically initialize __eabi()'s 'already_done' flag to
'1' if -mno-eabi is specified. This seems not to be the case, however.
>>It is probably trivial to conditionally compile to make the PPC call
>>__eabi() instead of __init() if we know when precisely to do it.
Yeah - I still like my approach (described in another post) better:
just give __USE_INIT_FINI__ a value [requires a tool 'spec' change,
however].
I just did some other test:
I compiled
const int svar=0xdeadbeef;
extern const int ext_svar;
int test(void) { return ext_svar + svar; }
with the command
powerpc-rtems-gcc -O -c -msdata=xxx test.c
- if I use -msdata=default or -msdata=eabi
--> svar ends up in the .sdata2 section
--> ext_svar ends up being accessed using R2
(actually, it is a R_PPC_EMB_SDA21 reloc
which is resolved by the linker into
R2 + an offset)
- if I use -msdata=sysv
--> svar ends up in the .sdata section
--> ext_svar is accessed via R13
- if I use -msdata=none
--> svar ends up in the .rodata section
--> ext_svar is accessed via a normal relocation
- if I use no '-msdata' option at all
This indicates, that powerpc-rtems indeed has the
-meabi option on by default.
-- Till
