Powerpc IRQ handling breaks strict EABI compliance
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Feb 13 19:16:29 UTC 2003
Sergei Organov wrote:
> Joel Sherrill <joel.sherrill at oarcorp.com> writes:
> > I agree with your analysis. The r2/r13 init needs to happen much earlier
> > than constructors can be executed.
> > So the simplest solution (to me anyway) is:
> > + bsp assembly startup initializes r2/r13 possibly using common code
> > derived from __eabi without the call to _init.
> > + call _init from _Threaad_Handler
> > Longer term, we can switch the toolset from non-EABI to EABI if that is
> > desirable.
> I also think this is the simplest solution. The only question remained is if
> the __eabi() is GPLed, and if so, if the "common code derived from __eabi"
> could be put into RTEMS ;-)
I would just leave it in gcc but it is licensed the same as RTEMS --
GPL with exception.
Looking at the code, it should be possible to ifdef eabi.asm on
__rtems__
and either "b __init" or return.
> Sergei.
joel at OARcorp.com On-Line Applications Research
