TCP/IP mbuf element size
Eric Norum
norume at aps.anl.gov
Thu Feb 13 19:46:28 UTC 2003
Charles Steaderman wrote:
> Hi all. I am working on an ethernet driver on an ARM CPU. When I am
> requested to transmit data out of the ethernet port, I am given a chain
> of mbufs. The chain is often times made up of many small buffers. For
> example, when replying to a 1500 byte ping request, I receive 2 mbuf
> chains. The first chain contains 3 elements of 14, 80, and 1420 bytes
> respectfully. The second chain contains 3 elements of 34, 20, and 8
> bytes respectfully. Unfortunately, the DMA controller on our chip does
> not deal well with small buffers, and causes underflow errors in our
> ethernet controller. Is there a way to tell the TCP/IP stack to give me
> fewer, but larger, mbufs? I really don't want to have to copy the data
> from the mbufs into a buffer prior to initiating a transfer.
What's wrong with copying to a single mbuf before transmission? Even if
there were a way to tell the TCP/IP stack to give you a single mbuf,
there TCP/IP stack would still have to copy from the packet fragment
mbufs to the single mbuf so there would be no real improvement from
having your driver do the copy itself.
Eric Norum norume at aps.anl.gov
Advanced Photon Source Phone: (630) 252-2793
Argonne National Laboratory
