SYSV / EABI compliance
Till Straumann
strauman at SLAC.Stanford.EDU
Tue Feb 18 18:21:36 UTC 2003
Chris Johns wrote:
> Till Straumann wrote:
>> I encountered one problem, however: Certain parts of
>> the system (mostly BSP specific stuff, but also
>> cpukit/libnetworking/kern/kern_sysctl.o) access
>> linker defined symbols in the following way:
> The sysctl related code is in:
> cpukit/libnetworking/sys/linker_set.h
> and needs a linker script change to collect all the variables into an
> array.
>> /* with -msdata=eabi, the compiler assumes
>> * this variable's address will be linked
>> * in the short data area.
>> extern int some_linker_defined_address;
>> /* use the address here */
>> yyy( (unsigned) & some_linker_defined_address )
>> When compiling with -msdata=eabi, a linker error results
>> because the compiler generates code who tries to locate
>> the address in a short data area while it is actually
>> an absolute address.
>> I solved this by declaring the bogus variable
>> (only the address has a meaning) as an array of unknown
>> size:
>> /* compiler doesn't know the size, hence access is
>> * through an absolute address
>> extern int some_linker_defined_address[];
>> yyy( (unsigned)some_linker_defined_address )
>> Does anyone have a better solution / suggestion?
> I do not understand what you needed to do for sysctl ?
Well, for the moment, I just compiled the relevant file
without -msdata but what would need to be changed are the
'linker_set.h' macro definitions so they declare the
linker defined addresses in a way similar to my example
above.
I guess it would look like this:
#define SET_DECLARE(set, ptype) \
extern ptype *__CONCAT(__start_set_,set)[]; \
extern ptype *__CONCAT(__stop_set_,set)[]
#define SET_BEGIN(set) \
(__CONCAT(__start_set_,set))
#define SET_LIMIT(set) \
(__CONCAT(__stop_set_,set))
-- Till
> Did you have to provide definitions for each sysctl variable that uses
> the TEXT_SET macro ?
