RFC: new RTEMS IRQ requirements
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Fri Feb 21 01:30:51 UTC 2003
Am Fre, 2003-02-21 um 00.11 schrieb Valette Eric:
> Joel Sherrill wrote:
> > Speaking strictly from a historical perspective. RTEMS used to make
> > more use of m4 and it was a portability pain in the (*&^%#. THe
> > situation may be better now but I somehow doubt it.
m4 is a PITA portability-wise, at least when using it to the extend
autoconf does :(
Though I doubt we would be hit by the issues autoconf is facing (In most
cases exceeded buffers - Other problems, such as limitations of the m4
language will probably not hit), I would prefer if we could get away
without using it
[I am inclined to think m4 would have been dead for quite a while if
autoconf and sendmail weren't using it;)]
> Sure, we should require gnu m4 to be installed not system provided m4.
> If memory serves I think ralph
Yes, Erik? ;)
> already pointed out that gm4 should be
> present for autoconf, automake anyway...
Right, autoconf requires gm4 and therefore probably already is available
in most U+ix-ish environments.
Ralf
