RFC: new RTEMS IRQ requirements (was: The eCos, QNX, ChorusOs irq handling API)
Sergei Organov
osv at javad.ru
Fri Feb 21 14:43:03 UTC 2003
Joel Sherrill <joel.sherrill at OARcorp.com> writes:
> Sergei Organov wrote:
> > Here is my list of requirements. The numbers in brackets are priorities (0
> > is the highest).
> > 1. (0) ISR attach.
> > 2. (1) Interrupt line enable/disable.
> > 3. (2) Small IRQ management overhead.
> > 4. (2) Short ISR latency.
> > 5. (3) Specification of the state the user ISR is invoked at.
> > 6. (4) IRQ ID and/or user argument being passed to user ISR.
> > 7. (5) Universal IRQ ID (or call it "vector" or "symbolic name").
> > 8. (250) ISR detach.
> > 9. (251) Interrupt priorities management.
> > 10. (252) Ability to implement drivers in a BSP-independent manner.
> > 11. (253) Ability to implement re-usable [P]IC managers.
> > 12. (254) IRQ ID being passed to user ISR separately from user argument.
> I think your requirement 10 is more important than you are giving it
> credit for. Reusing device drivers across BSPs and CPU families is
> important to reducing the effort required to build new BSPs and to
> reduce maintainenance for RTEMS as a whole. The performance is the
> libchip drivers is better than you might expect. The DEC driver in
> particular has been compared on both x86 and PowerPC targets to other
> OSes on the same hardware and always performs near the hardware limits.
I agree with your comments but they don't contradict with my list ;-)
I've intentionally built the list from the point of view of applications *I
care about* as I think that is what Till have asked us to do. Please note how
priority jumps at one point in the list. The applications I care about don't
use the features starting from (250) and I doubt they ever will -- thus low
priorities. If I were asked to build a list from the point of view of an RTEMS
designer, I'd change the priorities in the list significantly.
The resulting list is useless alone, but I believe Till will be able to
effectively merge lists got from different people to get to the most optimal
solution.
I'm sorry if initial lack of explanations caused a confusion.
> There are other approaches to BSP independent device drivers but the
> bottom line is that every time someone duplicates code to manage a
> particular chip, the maintenance goes up, risk of bugs being duplicated
> goes up, and the pain of making enhancements across the board goes up.
Also totally agree.
Sergei.
