OpenPIC (was Re: Bugs in the PPC/shared interrupt code + dec21140)
Till Straumann
strauman at SLAC.Stanford.EDU
Fri Feb 21 23:56:59 UTC 2003
Yeah, IMO also, the openpic driver is too much geared to the
motorola_powerpc BSP (it e.g. assumes there are 16 ISA IRQs present)
Unfortunately, I'm currently too loaded to take over this task,
sorry.
Kamen: I'd recommend you to file a PR with your fixes
-- Till
Kamen Penev wrote:
> There are other problems with openpic.[ch]. I recently implemented
> support for the MPC8245 EPIC, which is supposedly OpenPIC compliant. The
> existing code was not suitable for it without some substantial changes.
> For example, the current openpic implementation assumes that the
> register file in the OpenPIC is contiguous. However, the registers of
> the IRQs for the embedded MPC8245 devices are scattered all over the
> place into several groups. Here are my defs:
> BSP_EPIC_IRQ0 = BSP_EPIC_IRQ_LOWEST_OFFSET,
> BSP_EPIC_IRQ1 = BSP_EPIC_IRQ_LOWEST_OFFSET+1,
> BSP_EPIC_IRQ2 = BSP_EPIC_IRQ_LOWEST_OFFSET+2,
> BSP_EPIC_IRQ3 = BSP_EPIC_IRQ_LOWEST_OFFSET+3,
> BSP_EPIC_IRQ4 = BSP_EPIC_IRQ_LOWEST_OFFSET+4,
> BSP_EPIC_IRQ5 = BSP_EPIC_IRQ_LOWEST_OFFSET+5,
> BSP_EPIC_IRQ6 = BSP_EPIC_IRQ_LOWEST_OFFSET+6,
> BSP_EPIC_IRQ7 = BSP_EPIC_IRQ_LOWEST_OFFSET+7,
> BSP_EPIC_IRQ8 = BSP_EPIC_IRQ_LOWEST_OFFSET+8,
> BSP_EPIC_IRQ9 = BSP_EPIC_IRQ_LOWEST_OFFSET+9,
> BSP_EPIC_IRQ10 = BSP_EPIC_IRQ_LOWEST_OFFSET+10,
> BSP_EPIC_IRQ11 = BSP_EPIC_IRQ_LOWEST_OFFSET+11,
> BSP_EPIC_IRQ12 = BSP_EPIC_IRQ_LOWEST_OFFSET+12,
> BSP_EPIC_IRQ13 = BSP_EPIC_IRQ_LOWEST_OFFSET+13,
> BSP_EPIC_IRQ14 = BSP_EPIC_IRQ_LOWEST_OFFSET+14,
> BSP_EPIC_IRQ15 = BSP_EPIC_IRQ_LOWEST_OFFSET+15,
> BSP_EPIC_I2C_IRQ = BSP_EPIC_IRQ_LOWEST_OFFSET+113,
> BSP_EPIC_DMA0_IRQ = BSP_EPIC_IRQ_LOWEST_OFFSET+114,
> BSP_EPIC_DMA1_IRQ = BSP_EPIC_IRQ_LOWEST_OFFSET+115,
> BSP_EPIC_MU_IRQ = BSP_EPIC_IRQ_LOWEST_OFFSET+118,
> BSP_EPIC_UART1_IRQ = BSP_EPIC_IRQ_LOWEST_OFFSET+121,
> BSP_EPIC_UART2_IRQ = BSP_EPIC_IRQ_LOWEST_OFFSET+122,
> I can give you my versions of openpic.[hc], irq_init.c and irq[hc], if
> you want them.
> BTW, can anybody point me towards the OpenPIC spec? I could not find it
> at AMD's web site,.
> The MPC8245 EPIC manual is at
> http://e-www.motorola.com/brdata/PDFDB/docs/MPC8245UM_CH11.pdf
> Kamen
