VME device write
Feng, Shuchen feng at bnl.gov
Sun Feb 23 04:25:48 UTC 2003
Hi Till,
Thanks for your help.  I found the MMU BATs in the
latest release rtems-ss-20030128.  I hope this is the
latest patches you meant.
You  wrote :
> PS: as I mentioned. The latest patches I submitted for the MVME2306
> BSP do all of this for you. The BSP also provides a header 'VME.h'
> with macros and subroutines for address translation (the macros
> assume the default configuration the subroutine also works if you
> change the vmeUniverseMasterPort configuration - but is substantially
> slower...).
I did not find the 'VME.h' file anywhere.  Could it be called a different
name (e.g. vmeUniverse.h) ?
You also wrote :
> Note that I also have a EPICS devLib port which should work with the
> MVME2306.
That is what I thought.  However, I did not find devLib port for RTEMS
anywhere in the latest EPICS release or the RTEMS one.  Could you please
kindly
E-mail me the EPICS devLib port for RTEMS ?
Thanks,
Kate
