4MByte limit in IMFS for each file?
Angelo Fraietta angelo_f at bigpond.com
Sun Feb 23 23:03:24 UTC 2003
So what is the largest file size?
till wrote:
> Thomas.
> I hit the same limit when copying large files from TFTPFS to IMFS for
> loading them with CEXP.
> You have to increase the IMFS blocksize (the default being 128b -
> AFAIK, the max number of blocks is limited, hence increasing the
> blocksize will help) in the file
> cpukit/libfs/src/imfs/imfs.h
> look for IMFS_MEMFILE_BYTES_PER_BLOCK
> HTH
> -- Till
> Thomas Doerfler wrote:
>> Hello,
>> it's me again :-)
>> When I tried out my "fileio" sample, I hit a strange 4MByte limit
>> when creating files in the IMFS. I was working on a PC386 target with
>> 16MByte of memory (and most of it was always available on the heap).
>> When I tried to create big files (like 8MB), the write call always
>> failed (with a "no space left on device" error), directly after
>> reaching a 4MByte file size boundary.
>> This limit does not exist on the DOSFS, only when writing to the
>> IMFS. I tried it out on a MBX8xx system (with 16MByte of RAM) and
>> there I hit the limit also after 4MBytes.
>> I was browsing through the IMFS sources and did not find any reason
>> for this limitation, and I did not yet run the test with a debugger.
>> Any hints on that issue?
>> wkr,
>>     Thomas.
>> IMD Ingenieurbuero fuer Microcomputertechnik
>> Thomas Doerfler           Herbststrasse 8
>> D-82178 Puchheim          Germany
>> email:    Thomas.Doerfler at imd-systems.de
>> PGP public key available at: http://www.imd-
>> systems.de/pgp_keys.htm
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
