Error building RTEMS - Possible tools config error
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Feb 26 04:26:30 UTC 2003
Am Mit, 2003-02-26 um 05.14 schrieb Angelo Fraietta:
> I had an error attempting to build RTEMS. I did the following (from
> Eric' page)
> 1. ../rtems-ss-20030128/configure --target=i386-rtems
> --prefix=/opt/rtems \
> --enable-cxx --enable-rdbg --disable-tests
> --enable-networking \
> --enable-posix --enable-itron
> <snip>
> 2. Build and install RTEMS for one or more board-support packages
> using the target architecture configured in the previous step.
> The pc386 board support package which works on standard PC
> hardware would be specified as:
> make RTEMS_BSP=pc386
> however I got an error that
> i386-rtems-g++
> was not present.
Do you need c++?
If not, just remove "--enable-cxx" from the configure call above
(rtems++ won't be built then).
If you need c++, read on below.
> I looked in /opt/rtems/bin and it was not there so I made a soft link
> from i386-rtems-cpp to i386-rtems-g++, i.e.
> ln -s i386-rtems-cpp i386-rtems-g++
cpp is the C-preprocessor
g++ is the C++-compiler
So, the symlink is wrong.
> The build seems to be taking place just fine now.
> Is it possible that there is a problem in building of the RTEMS
> toolset or have I done something wrong?
I think you missed to build and install <target>-g++.
Add c++ to the list of languages being passed to configure when
configuring gcc/newlib:
configure ...
--enable-languages="c,c++"
Ralf
