Multiple dec2114x units on ppc
Valette Eric
eric.valette at free.fr
Wed Feb 26 09:10:22 UTC 2003
Valette Eric wrote:
> gregory.menke at gsfc.nasa.gov wrote:
>> > 4) In spite of the wrappers etc. the mods. do _not_ implement
>> > support for multiple devices correctly.
>> > This is actually a _very_ good example why having the
>> > 'on'/'off' handlers in the API is a BAD BAD idea.
> On/Off are per devices. If you want to make them generic (which they
> have never intended to be), you indeed need to have also and additionnal
> parameter or use the data passed back to make them work generic.
Thinking a little bit more, I this that if we have a handle in the API
to make some driver support multiple board, it should be given also to
the On/Off routine and contain the relevant information so that they can
correctly perform what you want.
Side comments : If you modify part of the API (e.g to get a vector or
get a handle to irq handler which is what gregm has done, you should not
complain for the resulting API not to be consistent...
-- eric
