Snapshot 20030128 broke my buildt
Angelo Fraietta
angelo_f at bigpond.com
Wed Feb 26 22:54:41 UTC 2003
Is there anything I can do now?
Joel Sherrill wrote:
>Till Straumann wrote:
>>I had submitted a fix for this
>>PR#340
>It is merged on both the release branch and trunk so the next
>tarballs will pick it up.
>Thanks for the speed Till.
>>HTH
>>-- Till
>>Angelo Fraietta wrote:
>>>I am getting the followingh link error when I try to build my exe (the
>>>rtems source builds fine)
>>>i386-rtems-gcc --pipe -B/opt/rtems/i386-rtems/pc386/lib/ -specs
>>>bsp_specs -qrtems -g -Wall -O4 -g -D_E_STL -I ../../../estl
>>>-I ../engine -I ../engineinterface -I ../hal_include -I ../link_driver
>>>-I ../../../threads/source -I ../../../mididriver -I
>>>../../../mididriver/hal_rtems -Wl,-Ttext,0x00100000 -o
>>>o-optimize/smart.obj o-optimize/diags.o o-optimize/rtems_init.o
>>>o-optimize/midioutput.o o-optimize/scheduler.o
>>>o-optimize/rtems_simulator.o o-optimize/commtasks.o
>>>/opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel
>>>/opt/rtems/i386-rtems/pc386/lib/no-mp.rel
>>>/opt/rtems/i386-rtems/pc386/lib/no-part.rel
>>>/opt/rtems/i386-rtems/pc386/lib/no-signal.rel
>>>../engine/o-optimize/sm_engine.a
>>>../engineinterface/o-optimize/sm_engineinterface.a
>>>../link_driver/o-optimize/sm_link_driver.a
>>>../link_driver/hal_rtems/o-optimize/sm_comm.a
>>>../../../threads/source/o-optimize/sm_rtems_active.a
>>>../../../threads/source/hal_rtems/o-optimize/sm_rtems_thread.a
>>>../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -v
>>>Reading specs from /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/specs
>>>Reading specs from /opt/rtems/i386-rtems/pc386/lib/bsp_specs
>>>rename spec cpp to old_cpp
>>>rename spec lib to old_lib
>>>rename spec endfile to old_endfile
>>>rename spec startfile to old_startfile
>>>rename spec link to old_link
>>>Configured with: ../gcc/configure --target=i386-rtems
>>>--prefix=/opt/rtems --with-gnu-as --with-gnu-ld --with-newlib --verbose
>>>--with-system-zlib --disable-nls --enable-version-specific-runtime-libs
>>>--enable-threads=rtems --enable-languages=c,c++
>>>: (reconfigured) ../gcc/configure --target=i386-rtems
>>>Thread model: rtems
>>>gcc version 3.2.1
>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/collect2 -dc -dp -N -e start -o
>>>o-optimize/smart.obj /opt/rtems/i386-rtems/pc386/lib/start.o
>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crti.o
>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtbegin.o
>>>-L/opt/rtems/i386-rtems/pc386/lib
>>>-L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1
>>>-L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib
>>>-Ttext 0x00100000 o-optimize/diags.o o-optimize/rtems_init.o
>>>../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -lgcc
>>>--start-group -lrtemsbsp -lrtemscpu -lc -lgcc --end-group -T
>>>/opt/rtems/i386-rtems/pc386/lib/linkcmds -lgcc
>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtend.o
>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtn.o
>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fdopen.o):
>>>In function `_fdopen_r':
>>>/opt/rtems/tools/build/i386-rtems/newlib/libc/stdio/../../../../../gcc/newlib/libc/stdio/fdopen.c:67:
>>>undefined reference to `_fcntl_r'
>>>collect2: ld returned 1 exit status
>>>make: *** [o-optimize/smart.exe] Error 1
>>>[angelo-Fraiettas-Computer:controller/source/hal_rtems_pc386]
>>>angelofraietta%
>>>This also happend with the pc386dx build as well as the pc386 build
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030227/07a7335c/attachment-0001.html>
