Snapshot 20030128 broke my buildt
Angelo Fraietta angelo_f at bigpond.com
Thu Feb 27 00:36:25 UTC 2003
That has fixed it. Thanks
Joel Sherrill wrote:
>Angelo Fraietta wrote:
>>Is there anything I can do now?
>Download the patch attached to PR340 and apply it. :)
>The URL is http://www.oarcorp.com/cgi-bin/gnatsweb.pl
>Login as guest with password guest.  If someone knows
>how to turn that into a URL, it would be handy. :)
>>>Till Straumann wrote:
>>>>I had submitted a fix for this
>>>>PR#340
>>>It is merged on both the release branch and trunk so the next
>>>tarballs will pick it up.
>>>Thanks for the speed Till.
>>>>HTH
>>>>-- Till
>>>>>I am getting the followingh link error when I try to build my exe
>>>>>(the
>>>>>rtems source builds fine)
>>>>>i386-rtems-gcc --pipe -B/opt/rtems/i386-rtems/pc386/lib/ -specs
>>>>>bsp_specs -qrtems   -g -Wall  -O4 -g       -D_E_STL    -I
>>>>>../../../estl
>>>>>-I ../engine -I ../engineinterface -I ../hal_include -I
>>>>>../link_driver
>>>>>-I ../../../threads/source -I ../../../mididriver -I
>>>>>../../../mididriver/hal_rtems       -Wl,-Ttext,0x00100000 -o
>>>>>o-optimize/smart.obj  o-optimize/diags.o o-optimize/rtems_init.o
>>>>>o-optimize/midioutput.o o-optimize/scheduler.o
>>>>>o-optimize/rtems_simulator.o o-optimize/commtasks.o
>>>>>/opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel
>>>>>/opt/rtems/i386-rtems/pc386/lib/no-mp.rel
>>>>>/opt/rtems/i386-rtems/pc386/lib/no-part.rel
>>>>>/opt/rtems/i386-rtems/pc386/lib/no-signal.rel
>>>>>../engine/o-optimize/sm_engine.a
>>>>>../engineinterface/o-optimize/sm_engineinterface.a
>>>>>../link_driver/o-optimize/sm_link_dri
>>>>>ver.a
>>>>>../link_driver/hal_rtems/o-optimize/sm_comm.a
>>>>>../../../threads/source/o-optimize/sm_rtems_active.a
>>>>>../../../threads/source/hal_rtems/o-optimize/sm_rtems_thread.a
>>>>>../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -v
>>>>>Reading specs from /opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/specs
>>>>>Reading specs from /opt/rtems/i386-rtems/pc386/lib/bsp_specs
>>>>>rename spec cpp to old_cpp
>>>>>rename spec lib to old_lib
>>>>>rename spec endfile to old_endfile
>>>>>rename spec startfile to old_startfile
>>>>>rename spec link to old_link
>>>>>Configured with: ../gcc/configure --target=i386-rtems
>>>>>--prefix=/opt/rtems --with-gnu-as --with-gnu-ld --with-newlib
>>>>>--verbose
>>>>>--with-system-zlib --disable-nls
>>>>>--enable-version-specific-runtime-libs
>>>>>--enable-threads=rtems --enable-languages=c,c++
>>>>>: (reconfigured) ../gcc/configure --target=i386-rtems
>>>>>--verbose
>>>>>--with-system-zlib --disable-nls --enable-versi
>>>>>Thread model: rtems
>>>>>gcc version 3.2.1
>>>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/collect2 -dc -dp -N -e
>>>>>start -o
>>>>>o-optimize/smart.obj /opt/rtems/i386-rtems/pc386/lib/start.o
>>>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crti.o
>>>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtbegin.o
>>>>>-L/opt/rtems/i386-rtems/pc386/lib
>>>>>-L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1
>>>>>-L/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib
>>>>>-Ttext 0x00100000 o-optimize/diags.o o-optimize/rtems_init.o
>>>>>m_engine.a
>>>>>../link_driver/o-optimize/sm_link_driver.a
>>>>>-lgcc
>>>>>--start-group -lrtemsbsp -lrtemscpu -lc -lgcc --end-group -T
>>>>>/opt/rtems/i386-rtems/pc386/lib/linkcmds -lgcc
>>>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtend.o
>>>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/crtn.o
>>>>>/opt/rtems/lib/gcc-lib/i386-rtems/3.2.1/../../../../i386-rtems/lib/libc.a(fdopen.o):
>>>>>In function `_fdopen_r':
>>>>>/opt/rtems/tools/build/i386-rtems/newlib/libc/stdio/../../../../../gcc/newlib/libc/stdio/fdopen.c:67:
>>>>>undefined reference to `_fcntl_r'
>>>>>collect2: ld returned 1 exit status
>>>>>make: *** [o-optimize/smart.exe] Error 1
>>>>>[angelo-Fraiettas-Computer:controller/source/hal_rtems_pc386]
>>>>>angelofraietta%
>>>>>This also happend with the pc386dx build a
>>>>>s well as the pc386 build
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.users.bigpond.com/angelo_f/
>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>There are those who seek knowledge to be known by others - that is VANITY
>>There are those who seek knowledge in order to serve - that is LOVE
>>    Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20030227/3cc6dba2/attachment-0001.html>
