code size latest snapshop versus 200206
Till Straumann
strauman at SLAC.Stanford.EDU
Thu Feb 27 03:02:56 UTC 2003
Chris Johns wrote:
> Till Straumann wrote:
>> These are the numbers for hello.exe on a PowerPC (SVGM, derived from
>> shared) BSP:
>> ss-20020301:
>> text data bss dec hex filename
>> 138568 4236 18673 161477 276c5 samples/hello.exe
>> ss-20030128:
>> 148820 5332 19205 173357 2a52d samples/hello.exe
> Made running some variation of the following :
> $ powerpc-rtems-nm --print-size --size-sort samples/hello.exe
> will help show what has increased.
Well - I compiled some statistics (see attachments).
The file 'hello.symdiffs' (generated using the [quickndirty]
diffcalc script)
lists the names of all symbols who's size changed from
ss-20020301 to ss-20030128 (I find readelf better suited than
nm --size-sort).
It's not clear who is really responsible for the net increase
as some things got bigger and some new symbols appear but other
symbols shrunk or disappeared.
There is also noticable fluctuation among small items.
_vfiprintf_r/_vfprintf_r and the two instances of __udivmoddi4
are candidates, though...
-- Till
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20030226/3536d8fc/attachment-0001.bin>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20030226/3536d8fc/attachment-0001.ksh>
