Snapshot 20030128 broke my buildt
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Feb 27 04:03:02 UTC 2003
Am Mit, 2003-02-26 um 22.46 schrieb Angelo Fraietta:
> I am getting the followingh link error when I try to build my exe (the
> rtems source builds fine)
> i386-rtems-gcc --pipe -B/opt/rtems/i386-rtems/pc386/lib/ -specs
> bsp_specs -qrtems   -g -Wall  -O4 -g       -D_E_STL    -I ../../../estl
> -I ../engine -I ../engineinterface -I ../hal_include -I ../link_driver
> -I ../../../threads/source -I ../../../mididriver -I
> ../../../mididriver/hal_rtems       -Wl,-Ttext,0x00100000 -o
> o-optimize/smart.obj  o-optimize/diags.o o-optimize/rtems_init.o
> o-optimize/midioutput.o o-optimize/scheduler.o
> o-optimize/rtems_simulator.o o-optimize/commtasks.o
> /opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel
> /opt/rtems/i386-rtems/pc386/lib/no-mp.rel
> /opt/rtems/i386-rtems/pc386/lib/no-part.rel
> /opt/rtems/i386-rtems/pc386/lib/no-signal.rel
> ../engine/o-optimize/sm_engine.a
> ../engineinterface/o-optimize/sm_engineinterface.a
> ../link_driver/o-optimize/sm_link_driver.a
> ../link_driver/hal_rtems/o-optimize/sm_comm.a
> ../../../threads/source/o-optimize/sm_rtems_active.a
> ../../../threads/source/hal_rtems/o-optimize/sm_rtems_thread.a
> ../../../mididriver/hal_rtems/o-optimize/rtems_midi.a -lstdc++ -v
Where does this -lstdc++ come from?
Linking c++ applications using
gcc <args> -lstdc++
is wrong. You must use
g++ <args>
instead.
Ralf
