code size latest snapshop versus 200206
Thu Feb 27 17:18:05 UTC 2003
till wrote:
> Joel Sherrill wrote:
> >till wrote:
> >>>Is the newlib version changing between these two points?
> >>yes - I don't have the exact version numbers at hand, though.
> >That's a big deal if newlib went from 1.10.0 to 1.11.0.  It
> >is very possible that the new newlib version has more dependencies
> >than the old one.  Same tracking rules apply and likely the
> >same types of fixes.  Break files apart, eliminate calls to
> >complex routines with simpler ones.
> >Could someone confirm that the smaller size is with newlib 1.10.0
> >and the larger size is with newlib 1.11.0?
> >--joel
> My numbers are ss-20020301-newlib-1.9.0 vs ss-20030128-newlib-1.11.0
Yikes!! That's a long way to compare against.  A LOT of variables.  The
gcc version probably changed also, didn't it?
> -- Till
