more multiple dec21140 on ppc  <fixed>
    Valette Eric
    eric.valette at free.fr
    Fri Feb 28 18:36:58 UTC 2003
gregory.menke at gsfc.nasa.gov wrote:
> gregory.menke at gsfc.nasa.gov writes:
>  >  >  > Till Straumann writes:
>  >  >  >  > > (sorry Till, I sent a copy to to alone by accident...)
>  >  >  >  > > I'm still working on it and have little more to report except that its
>  >  >  >  > > increasingly looking like something isn't quite configured right in
>  >  >  >  > > MPIC or the PBC.
>  >  >  >  > > Shifting the onboard dec to MPIC irq 2 (which its supposed to be wired
>  >  >  >  > > to) causes it to stop receiving interrupts (and I am changing its
>  >  >  >  > > INTERRUPT_LINE value to 2, with name = 18).  I've only been able to
>  >  >  >  > > make the onboard dec operate under its ISA irq 10.
>  >  >  >  > Hmm - I cannot reproduce your problem on my mvme2306 board.
>  >  >  >  > Here's what works (with both, the original dec21140.c and the
>  >  >  >  > modified version you sent me a couple of days ago) on my board:
>  > Till, now I understand what you mean by not wanting a struct sockaddr
>  > for interrupts, I just learned about the pci swizzle...  I agree with
>  > you.
>  > If I have the onboard ethernet on ISA 10, and the cpci board vectored
>  > for service on all 4 cpci interrupt lines, with the onboard ethernet
>  > pinging continuously, I will sometimes see MPIC irq 11 asserts.  It
>  > seems like something is stopping the MPIC from receiving/servicing the
>  > interrupts, possibly unless MPIC irq 0 is coincidentally being
>  > signalled.  I wonder if it might be a subtle inservice/ack problem...
> The problem was the polarities and senses arguments to openpic_init
> were reversed.  This apparently doesn't interfere with MPIC irq 0, but
> on the ppc it appears to mess up the other irq's.  Perhaps the
> different openpic on Till's vme board handles the situation enough
> differently so the bug is masked.  I've confirmed this by successfully
> running the onboard ethernet on mpic irq 2.
This might well be board dependend. I even think that I have had two
different MCP750 board revision with different incompatible polarity for
IDE. I was forced to test the revision and change the setting depending
on the board revision to run linux...
One was booting and the other just loop asserting the interrupt always
looking the bott while the same binary was working fine on the other
board...
    __
   /  `                   	Eric Valette
  /--   __  o _.          	6 rue Paul Le Flem
(___, / (_(_(__         	35740 Pace
Tel: +33 (0)2 99 85 26 76	Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
