int8_t typedef problem
Stephen Holford SHolford at WESCAM.com
Tue Jan 7 14:29:51 UTC 2003
Hi Joel
> Thanks.  What about the other intXX_t types?  Should they say signed?
Not necessary as all arithmetic types other than chars and bitfields are
signed by default. One thing to note with the "signed" keyword is it
isn't K&R compatible, it was introduced in the C89 standard. This is the
likely reason that gcc has the -fsigned-char, etc. command line switches...
Steve
